Dare County 800 system....
RMPDCOP
Nashville, NC
Since there appears to be some confusion.....
VIPER Dare SO Dispatch is patched at the console level to Dare 800 SO Dispatch
VIPER Beach Law Dispatch is patched at the console level to Dare 800 Beach Law 1
VIPER Dare EMS Dispatch is patched at the console level to Dare 800 EMS Something...
Mike
And there you have it straight from the horses mouth. Thanks Mike for clearing this up.
Webodisk
Silent key.
Virginia Beach,VA
and I hate to say it but after todays trip tp the OBX encryption has come to OBX 14784,14788,14559, and a new TG for the database Duck event 1 14707
Webodisk
Silent key.
Virginia Beach,VA
Not as far as I know, just those 3 TG were encryption, all other Tg were in the clear, the pro 106 did a killer job with a vehcle mounted BMAX-1000 on my jeep
kh11
Hmm - not hearing anything
I did an import of the Dare public safety system data from the database into Win500 and programmed my PSR500. So far after a few hours listening today in Nag's Head I have heard exactly nothing. However the signal strength is consistently maxed out. Is the system very active? Should it be set as "P25 Auto" or "P25 Manual"? Should the freq list show anything other than the control channel (859.9875)?
(On the other hand, the VIPER system has had a fair amount of activity.)
kh11
P25 auto, worked for me
Nothing received so far this morning but signal strength is a full 5 bars. Trunking tables default, multisite mode off. If I look at the list of trunking tables, it is all zeroes. But I'm guessing that's all probably correct.
Presumably shift change should be happening shortly, so we'll see if any traffic shows up.
KX4KDH
Powells Point, NC
There is ALWAYS something happening on this system.... I am surprised you are hearing nothing....
kh11
Now that I think of it.... Try putting the other frequencies in the list
OK, I've just entered them. We'll see if that helps. Clearly something isn't configured properly, since the signal strength is quite high.
kh11
Hmm... the signal strength is popping from max to zero as it scans, and there is no "T" displayed. I just had a quick burst of reception during which the T flickered, but something is clearly still not right unless P25 systems look differently on the display from Moto 800/900. On those, I get at least some signal strength all the time during the scan, and the T stays displayed. I'm going to poke around in Win500 to see if there are other settings I may have missed.
kh11
Well, I'm about to give up. I reimported the system. With just the control channel listed in Win500, I see high signal strength but the "T" on the display flickers on and off. I'm guessing maybe that corresponds to data. I've seen it stop on a couple of TGs for a couple of seconds, but no audio other than fragments that a heard twice on DCSO Disp. It's acting like it's out of range, but with the signal display so high that's hard to believe. (I'm on the beach in Nag's Head.)
This is the first time I've tried to monitor a P25 system. I must be missing something.
murrayustud
KI4DCR
raleigh,nc
When I was down there a few weeks ago I could easily receive the system in Kill Devil Hills near 3rd street, but if I went towards Nags Head I got zero, nothing, from KDH north no problems, but Nags Head on south or west, nothing....
kh11
Wow, I can't imagine a system with coverage that spotty, especially with the terrain as flat as it is around here. And as I say, the control channel is showing very decent signal strength.
kh11
I tried reimporting it again, but this time changed some options - turned off "CC Only" for one. Now it shows all of the frequencies, and when I do "analyze" it shows both the WACN and N numbers (it just had the WACN before). I have seen it pause on Beach Law a couple of times, and once there was a brief burst of audio.
If I had to make a wild guess, I would say that the control channel is the only one with enough signal strength to be received.
KX4KDH
Powells Point, NC
Wow.... I don't have any of the trouble you guys are having.... The only thing I notice is when I go mobile, I get the same "artifact" that the system users are getting....
kh11
Not using a PSR500 though. I was hoping you were and could share the file.
