DSD+ 2.520 Released Sunday, January 19, 2025
seagravebuff60
Short Bus Reject
I can confirm that DCC/NAC/RAN & Frequency info is back in the Event file for me; thanks for the update addressing this!
As a side note, I did get a popup saying this before I updated. Im assume this means the P25 talker alias data won't work with the older versions. Just an FYI.
2025/01/20 08:23:01 Alias server said: "Use the DSD+ Misc menu to update your copy of DSD+"
2025/01/20 08:23:01 P25 talker alias data acquisition and display is disabled
kd7jfv
Bend, Oregon
Good morning. After installing DSDplus 2.520 I'm receiving the following error.
Error
1R DSD+ 2.520
Unrecoverable error encountered:
Exception number = 0xC0000005 (Access Violation)
Instruction address = 0x422B4E
Thread = #27
Action: Read of address 0x32 (50)
Register dump:
DS: 0000002B CS: 00000023 IP: 00422B4E EAX: 006A27E8
ES: 0000002B SS: 0000002B SP: 2E91FF5C EBX: 089BE3D8
FS: 00000053 Fl: 00010246 EBP: 2E91FF74 ECX: 006A27E8
GS: 0000002B ESI: 08989A58 EDI: 004229B8 EDX: 00000032
Press Ctrl-C to copy this text to the clipboard
OK
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Error
1R DSD+ 2.520
Thread = #27
Register dump:
OK
Might want to send that to dsdplusfastlane@gmail.com. Although, are you positive that your directory/all your files are in a location where DSDPlus has file-level authorization to read/write/etc ? You may want to make sure of that.
kd7jfv
Bend, Oregon
Same location. Same folder as where I’ve been running dsdplus for years. Only thing new was copy/paste new dsdplus.exe into the folder.
radiotrack1
Lumberton, NC
The updated notes state that -_3 or -_11 are no longer supported and to use the menus to control it. My question is I only want the channel activity and the event log windows up and everything else to start minimized so how do I accomplish this with the menus?
This is already being discussed in two threads.
u2brent
OAMPT
KRWDPAXKRS1
FYI,
DSD+ 2.522 Released 2025 01/23
Some stability improvements.
slicerwizard
Toronto, Ontario
Short answer - all of the windows start up in the condition (minimized / not minimized) that you left them in.
Exception is the console window; it has a menu option to control its starting state.
