DSDPlus DSD+ Faslane help please
Forts
Ontario, Canada
Link as in a link to the system in the database here. I can't tell you what steps you need to take until I can see what you are trying to listen to.
chrisc93
Cape breton
If you are back to talking about DSDPlus, you can do trunktracking with a single dongle. What you will get with using two is the ability to retune to a talkgroup you have programmed to a higher priority.
With a P25 system, you should only have to tune to the Control Channel and the program will use the transmitted bandplan to tune the other channels. Open FMP24 and the 1R batch file that opens DSDPlus. They are easily customized via batch file editing or using the menu in the DSDPlus Event Log window.
chris
ok thanks ill try that im still just using the free version right now to so i dont have 1r.bat or fmp24 yet...does the free version trunk track ,, i am going to try getting a subscription to fastlane again but im just curious if the free one did it
chrisc93
Cape breton
And the link what do u mean ,, the listing on this site ? Like the control frequencies nac and what not ,, i seen it all come in on the dsd side but no trunking ,, so when I plug in that orange stick in what order do I open fmp ,, fmp , then the cc then the vc ? Or hows that work i should have the orange stick this week coming sometime
oh sorry just wasnt sure what you ment ,, Maritime Public Safety Radio Network (MPSRN) Trunking System, Various, Multi-State - Scanner Frequencies ,, trying to hear the cape breton ones this one being closest Boularderie Site Details (Maritime Public Safety Radio Network (MPSRN))
Forts
Ontario, Canada
Well, I hate to break it to you but... You see the DE in the Cape Breton PD entries? That's Digital Encrypted.
Encrypted = you don't listen 😐
cg
Connecticut
run FMP24
click on the FMP24 window
Type in the control channel frequency [enter]
make sure the bandwidth for p25 is either 12.5 or 9.5
put the noise floor around the second blue line up. [g] to go down [G] to go up
run DSDPlus via 1r.bat
should see system info start right away.
READ the Notes file.
chris
chrisc93
Cape breton
run FMP24
chris
still dont seem like it wants to work
Forts
Ontario, Canada
ok so its open i hear static ,its saying no freq files found ,, i only have fmp opend
You have to tune it to a frequency to be able to hear something. Click on the FMP window and type in a known local frequency, or maybe a weather channel and you should hear something.
In order to get that audio to DSD though, it has to be properly piped from FMP. The two need to link and work together.
cg
Connecticut
Are you using the supplied batch files? Tune to the desired Control Channel.
Once they are started, move the windows so they all show, take a screenshot and post the image.
chris
a417
lines 17 thru 33 of Notes.txt said:
If you are a new Fast Lane member:
If you already have a DSD+ 1.101 folder set up, skip step 1.
1: If you do not have a DSD+ folder set up yet, go to DSDPlus.com and download
the most recent public version of DSD+ (currently 1.101); also download the
DLL package.
Unzip all of the files to a folder on your PC. We recommend using C:\DSDPlus.
2: You should also download this file:
ftp://ftp.fftw.org/pub/fftw/fftw-3.3.5-dll32.zip
Extract the libfftw3f-3.dll file from the zipfile
(it is the largest file in the zipfile) and copy it to your DSD+ folder.
  • Like
Reactions: aaz
aaz
Horta - Azores
Hello everyone,
I am a fast lane user and I have the latest version. 2.303 paid
Can someone help me with the command I have to use to view the mototrbo basic privacy key number in the log?
The network in question uses BP. The problem is that Fast Lane does not show it .... :unsure:
Please see the log attach, is it due to the TXI? log- example(( Enc TXI Group call; TG=14 RID=254 Slot=1 Alg=BP 4s ))
I already applied the -4 and it didn't make any difference
Thank you very much
DJ
