DSD+ Status
DSDPlus
DSDPlus,
Thanks again for all your work on this. The following are some samples of NXDN with various combinations of Caller ID, UID and GID being used:
Sample Call Type Unit ID (Own) Unit ID Name (Own) Calling RAN
1 Individual Call 1 1 ABCDEF 2 GHIJKL 1 NXDN9600 Conventional
2 Individual Call 2 2 GHIJKL 1 ABCDEF 1 NXDN9600 Conventional
3 Individual Call 3 3 xyz 65519 Test 1 NXDN9600 Conventional
4 Individual Call 65519 65519 Test 3 xyz 1 NXDN9600 Conventional
5 Group Call 65519 65519 Test GROUP ID 1 1 NXDN9600 Conventional
6 Group Call 65519 65519 Test GROUP ID 9 1 NXDN9600 Conventional
7 Individual Call 65519 65519 Test 1 ABCDEF 1 NXDN4800 Conventional
8 Group Call 65519 65519 Test GROUP ID 9 1 NXDN4800 Conventional
Samples:
Zippyshare.com - Sample1.wav
Zippyshare.com - Sample2.wav
Zippyshare.com - Sample3.wav
Zippyshare.com - Sample4.wav
Zippyshare.com - Sample5.wav
Zippyshare.com - Sample6.wav
Zippyshare.com - Sample7.wav
Zippyshare.com - Sample8.wav
Further samples can be provided if these are helpful
Jim
Feature added.
racingfan360
Hi DSDPlus...that's excellent thank you. Really looking forward to this release now !!!!
Just looking at some of the decodes, are they being clipped a bit? For example, The call with "src=65519:519 Test" I might have expected to see the full Unit ID Name of the caller being displayed after the ID number (UID) of the calling unit ie I expected to see "src=65519:65519 Test" I think the Unit ID Name can be up to a maximum of 14 alphanumeric characters.
For these samples I just happened to include the unit ID number in the Unit ID name to simply programming/testing, but in my experience the name is usually just an alphabetic name.
HTH
Jim
DSDPlus
HTH
Jim
Broken feature repaired. Responsible parties sacked.
racingfan360
LOL...nice one. Thanks DSDPlus. Now if only we could encourage you to sneak a copy of this version of DSD+ onto zippyshare for us to have a play for ourselves ;-)
Saint
Fort Erie Ontario Canada
DSD+ Subtitles
will the new DSD+ Be able to append more information to the audio files,
When listening to a DMR Motorola Capacity Plus (TRBO) system the subtitle file shows the date and time of the audio files, also it shows CC and the slots information.
Will the new DSD+ program be able to show what Group or ID the Audio is coming from so we can tell who the user is. it would be a lot easier to figure out who is on the system.
Like if group 57 or ID started to talk the program would append the group to the audio.
Steve
yeomandroid
Re: DSD+
Ill bump that!
Thanks a million to all the programmers and beta testers,as well as the folks contributing samples from local systems to the team so they can create a broad working application.
We know you do this because you love it,and offering it to us is very much appreciated!
I'll second that. Hoping to give the new release a test drive soon. Just wish I had more time to fiddle around with SDR# and all the neat things it can do. Thanks to everybody, this looks like a lot of work and it's much appreciated.
DSDPlus
Steve
Yes.
tikev
Quebec, Canada
Hi,
Do you have an update about when the new release will be available for download?
Thank you very much for your work!
Markb
Planet Earth
Really looking forward to the update.
Are there any planned changes to the way the program is started or is it always going to use the CLI and switches?
I don't know enough about writing software to know whether or not a GUI can be made to adjust parameters.
Ghstwolf62
Clifton Forge Virginia
The current version has a GUI that can be installed on SDR Sharp so you can do everything from within that program
Markb
Planet Earth
That's cool, but I am not a fan of SDR#. I would rather slog through the CLI if that's what it comes down to.
Ghstwolf62
Okay. Not even sure what that is but I downloaded the GUI from a Russian developer and put it into SDR Sharp and it works great not to mention easily. Select all aspects such as audio source and output and type of system etc.
I need easy I'm afraid. LOL
So Far Away....
Ah okay thanks. I've used it but didn't know what it was called besides a PITA. ;) I find the improvements allowing simplified operation to be a Godsend. Makes life so much easier.
DSD+ SDR# Plugin GUI. Allows control of DSD+ from SDR#
PITA Is correct!...CLI is so.....1982...
DSDPlus
Greetings from 1982. DSD+ release is pending NEXEDGE control channel decoding cleanup. We need more testers for this feature. Please PM with system details.
