If they work you can keep them. I created a folder in my directory labeled misc and it’s filled with everything I want but don’t need in the main directory.
So next up, Hytera XPT trunking. I don't have any systems locally to try out. Does DSD+ Fast Lane trunktrack these and how do you figure out the LSNs? What little I can find online is they work similar to LTR or Cap+ and have no system ID, only site IDs, up to 8 TDMA repeaters for 16 slots max. So, what's the syntax for entering them in DSDPlus.networks, DSDPlus.frequencies, and DSDPlus.sites so I can write this up? We just have to make up a Network ID like with Cap+? Thanks.
LRRP is purple in the event window. It will say either something about LRRP or ARS. And it will not always contain latitude/longitude/speed/direction. It will be blatantly obvious if it does.Can someone share some high-resolution screenshots of LRRP data in the Event Log and the map itself? I don't have this in my area, but want to include an example. Thanks.
No. When you launch the program it will see 2 dongles. Look in the notes and look for “use first available” dongle. It’s in Fmp24 help. Believe it only applies to Rtl sdr dongles.For running a 2-dongle setup using RTL-SDRs, do the dongles have to have different serial numbers?
So how come some features on FMP24 don't work on FMPA? For example, FMP24 lets you disable / enable auto center tuning with -a0 / -a1, but FMPA gives an error with that command. FMP24 lets you tell it to make the bandwidth stay put with -b-7.6, but same thing with FMPA. It gives an error. And then if you put a DELAY in your .scanlist entries, FMP24 does it, but FMPA ignores it and resumes scanning right away. FMPA also scans a lot slower.
I know about the Cap+ disambiguation, but is there a way to use color codes, RANs, NACs, etc. as an actual audio squelch so that DSD+ only unmutes if it gets the tone you tell it? And, is there CTCSS / DCS available for analog ?
As I stated above, FMPA is to control Airspy receivers. The Airspy has its own features and limitations and will not perform like a dongle, and using FMPA to tune a dongle is just asking for problems. You should use FMP24 for that.So how come some features on FMP24 don't work on FMPA? For example, FMP24 lets you disable / enable auto center tuning with -a0 / -a1, but FMPA gives an error with that command. FMP24 lets you tell it to make the bandwidth stay put with -b-7.6, but same thing with FMPA. It gives an error. And then if you put a DELAY in your .scanlist entries, FMP24 does it, but FMPA ignores it and resumes scanning right away. FMPA also scans a lot slower.
