Duke Energy P25 System
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
The NAC on both frequencies quickly jumps between 001, 009, & FFF back and forth
Not to hijack a thread, but just an FYI, since the recent FL update, some non-TDMA (i.e. FDMA) P25 control channels in my area (Sacramento, CA) are also doing this flipping back and forth of the NAC, clogging up the event window. Specifically on systems that have TDMA band plans. So this may just be an error in the software, not necessarily with the new TDMA control channel decoding function itself.
If I switch the program function from whatever mode it's currently in (let's say CC-only monitor), then switch it to another function (let's say CC/VC monitor), it sometimes fixes the problem.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Unrelated, but how can I hear the audio back after recording raw audio? Where in the files would it be?
If you were to press "R" (when focused on a DSDPlus window), it would start raw audio recording to a .wav file (in your DSDPlus folder). It would be called something like DSDPlus-Raw-Audio-*.wav with the * being a specific timestamp. You press "R" in DSDplus to start the recording, and then you press "R" again to gracefully stop the recording. 30-60 seconds of audio is probably good.
Then, if you wanted to play it back, you'd fire up a Command Prompt, navigate to your DSDPlus directory, and type something like:
DSDPLUS ? dsdplus-raw-audio-blahblahblah.wav
That will play back the previous recorded raw audio wav file by the same name.
west-pac
Im so lost! Last I knew the Duke sites were not decodable. Is there a new version of Fast Lane that came out in the past few days?
AuggieActually
Southwest BFE, OH
Yep, a new version is out, but it's seemingly not quite perfect yet. It sometimes only decodes bad messages or says no sync, even with good signal strength.
Here are DSD recordings from a couple of sites near me, if anyone wants to mess with them. One decodes a neighbor list, but not frequencies, and the other vice-versa.
  • DukeP25.zip
scannerboy02
I'll be awaiting an update for NC on that list lol
I check the applications at least once a week, usually more.
Being that they have said this is going to be a slow growth over the next several years I imagine they won't start on the next region until Florida and Midwest are complete but you never know. I does seem like they are working rather quickly, at least quicker than I thought they would be.
mtindor
OH/WV DB Admin
Has the new DSDPlus update been working better on this system?
v3.457 has been working well, from what I can see (using raw audio files that others had posted). In v.3457:
If a site CC is transmitting info on alternate CCs and peers (and pretty much all these sites are), all that info is now being decoded and saved to the DSDPlus.P25Data file. In v2.345 it was an either/or thing, whereby you would monitor a site CC and would either all of the control channels and no peers, or just the active control channel and all the peers. So definitely improved. Many of the raw audio recordings that were posted of TDMA CCs recently are bad recordings (and unfortunately I propagated those bad recordings by linking them on my website and in forums). For any raw audio .wav files that were of a reasonable signal with proper bandwidth, DSDPlus is now copying everything 100%.
However, on TDMA CC sites, at least the ones for which I've piped the raw audio through DSDPlus v.3457, you will not see the frequencies in the Channel Activity window. You will only see the channel numbers there. But, all of the information is being written to the DSDPlus.P25data file.
In summary, the latest DSDPlus will get all of the relevant information (WACN / SysID / Site ID / NAC / all CCs / all peers) and write it to the DSDPlus.P25data file, at least for any/every Duke site reported thus far.
scannerboy02
Updated information for sites I have received so far in the greater Cincinnati area. I plan to visit all of the sites in Ohio, Kentucky and southeast Indiana this weekend. Something I have noticed is that they are reusing frequencies on sites that are in rather close proximity to each other. In several places around Cincinnati I can hear the control channel signals from more that one site on the same frequency at the same time and when this happens the DSD+ software (understandably) gets rather confused and I have to move to another area to get a clear decode.
Bold = New information
** = Confirmed site location
? = Site location not confirmed
?? = Site location not confirmed but highly likely
1.1 - CC= 8-544 - 854.4125 - ?
Site Name: Alexandria Cooper, Campbell County, Kentucky ?
Call Sign: WRJM735
WACN: 91F14
System ID: 201
RFSS: 2
Site ID: 2
NAC: 002
8-768 - 855.8125 - CC
Neighbors
52.52 - CC= 8-936 - 856.8625 - Ryland Heights
57.57 - CC= 8-584 - 854.6625 - Verona
63.63 - CC= 8-544 - 854.4125 - Zimmer Hill
6.6 - CC= 8.888 - 856.5625 - ?
7.7 - CC= 8-1340 - 859.3875 - ?
Site Name: Brecon Radio, Hamilton County, Ohio **
Call Sign: WRJK869, WRJM686
WACN: 91F14
System ID: 201
RFSS: 10
Site ID: 10
NAC: 00A
8-1288 - 859.0625 - CC
8-1360 - 859.5125 - SCC
8-1584 - 860.9125 - SCC
Neighbors
No neighbors list reported
Site Name: Dana, Hamilton County, Ohio **
Call Sign: WRJM686
WACN: 91F14
System ID: 201
RFSS: 22
Site ID: 22
NAC: 016
8-924 - 856.7875 - CC
8-1092 - 857.8375 - SCC
8-1336 - 859.3625 - SCC
Neighbors
10.10 - CC= 8.1288 - 859.0625 - Brecon
52.52 - CC= 8.936 - 856.8625 - Ryland Heights
56.56 - CC= 8.692 - 855.3375 - ?
63.63 - CC= 8.544 - 854.4125 - Zimmer Hill
24.24 - CC= 8.648 - 855.0625 - ?
Site Name: Dunlap, Hamilton County, Ohio **
Call Sign: WRJK869
WACN: 91F14
System ID: 201
RFSS: 26
Site ID: 26
NAC: 01A
8-704 - 855.4125 - CC
8-1052 - 857.5875 - SCC
8-1372 - 859.5875 - SCC
Neighbors
10.10 - CC= 8-1288 - 859.0625 - Brecon Radio
40.40 - CC= 8-884 - 856.5375 - Lawrenceburg
69.69 - CC= 8-600 - 854.7625 - ?
30.30 - CC= 8-896 - 856.6125 - ?
Site Name: Lawrenceburg, Dearborn County, Indiana ??
Call Sign: WRJK869
WACN: 91F14
System ID: 201
RFSS: 40
Site ID: 40
NAC: 028
8-884 - 856.5375 - CC
8-1044 - 857.5375 - SCC
8-1204 - 858.5375 - SCC
Neighbors
26.26 - CC= 8-704 - 855.4125 - Dunlap
26.26 - CC= 8-1052 - 857.5875 - Dunlap - CC rotated
61.61 - CC= 8-600 - 854.7625 - Wilmington Substation - CC rotated
61.61 - CC= 8-644 - 855.0375 - Wilmington Substation
Site Name: Ryland Heights, Kenton County, Kentucky ?
Call Sign: WRKI239
WACN: 91F14
System ID: 201
RFSS: 52
Site ID: 52
NAC: 034
8-936 - 856.8625 - CC
Neighbors
2.2 - CC= 8-768 - 855.8125 - Alexandria Cooper
22.22 - CC= 8-924 - 856.7875 - Dana
Site Name: Verona, Boone County, Kentucky ??
Call Sign: WRJM686
WACN: 91F14
System ID: 201
RFSS: 57
Site ID: 57
NAC: 039
8-584 - 854.6625 - CC
8-772 - 855.8375 - SCC
8-1180 - 858.3875 - SCC
Neighbors
58.58 - CC= 8-1412 - 859.8375 - ?
Site Name: Wilmington Substation, Dearborn County, Indiana ??
Call Sign: WRJM302
WACN: 91F14
System ID: 201
RFSS: 61
Site ID: 61
NAC: 03D
8-600 - 854.7625 - CC
8-644 - 855.0375 - SCC
8-1096 - 857.8625 - SCC
Neighbors
Site Name: Zimmer Hill, Clermont County, Ohio ??
Call Sign: WRKI239
WACN: 91F14
System ID: 201
RFSS: 63
Site ID: 63
NAC: 03F
8-544 - 854.4125 - CC
8-896 - 856.6125 - SCC
8-1212 - 858.5875 - SCC
Neighbors
n8yid
Preble County, Ohio
Finally got a chance to update DSD+....
From the Dicks Creek site in Monroe....
Getting a NL with 17.17 - CC - 856.8625
and the 56.56 neighbor as well ( 56.56 - CC - 855.3375 )...
Seeing this after I posted - 855.3375 is on license WRJM686 for location #7 ( Valley View Office - Northbend Road - Cincinnati)....
mtindor
OH/WV DB Admin
Call Sign: WRJM735
WACN: 91F14
System ID: 201
RFSS: 2
Site ID: 2
NAC: 002
Neighbors
WACN: 91F14
System ID: 201
RFSS: 10
Site ID: 10
NAC: 00A
Neighbors
Call Sign: WRJM686
WACN: 91F14
System ID: 201
RFSS: 22
Site ID: 22
NAC: 016
Neighbors
Call Sign: WRJK869
WACN: 91F14
System ID: 201
RFSS: 26
Site ID: 26
NAC: 01A
Neighbors
Call Sign: WRJK869
WACN: 91F14
System ID: 201
RFSS: 40
Site ID: 40
NAC: 028
Neighbors
Call Sign: WRKI239
WACN: 91F14
System ID: 201
RFSS: 52
Site ID: 52
NAC: 034
Neighbors
Call Sign: WRJM686
WACN: 91F14
System ID: 201
RFSS: 57
Site ID: 57
NAC: 039
Neighbors
Call Sign: WRJM302
WACN: 91F14
System ID: 201
RFSS: 61
Site ID: 61
NAC: 03D
Neighbors
Call Sign: WRKI239
WACN: 91F14
System ID: 201
RFSS: 63
Site ID: 63
NAC: 03F
Neighbors
I've updated a few sites. Sites with just peer updates wont' turn green. Sites that I added control channels to are green. And the one new site (Grants Lick) is green. I know you call it Alexandria Cooper MW, but does anybody in that area know who/why/what as far as why the site would be called Alexandria Cooper? Probably not. I'd be interested to know though. I googled the name and didn't come up with anything. So I left it off the site name.
Thanks for the updates.
