SDS100/SDS200: False Information Displayed When Monitoring Capacity Plus On SDS100
JASII
Memory Capacity
I have a Uniden SDS100. I have been monitoring a Motorola two RD frequency Capacity Plus system. I have it in the ID Search mode. A few times it appeared as if some "new' talkgroups were being monitored. However, now that I have listened a bit more, it seems like it might actually be individual calls or private calls showing up as new talkgroups.
I don't have a lot of experience monitoring Capacity Plus systems on a Uniden SDS100, so this might already be a known issue.
Ubbe
Stockholm, Sweden
It's not just the SDS100, it's the same issue with Unidens other SD card scanners, that private calls sometimes turns up as a TG call. It's probably Unidens issues with control channel decode errors that are at fault as if you scan the same cap+ system using conventional monitoring instead of MotoTrbo or OFT if works as it should with private calls.
/Ubbe
