FD Tone Notify - New Tone Detection Software Released
webstar22
RenfrewCountyScanner.com
Ontario, Canada
Anyone ever use a SDR in Linux CLI with FDNotify, how did you do it if you did.
nightmicu
`Sep-03-2024 17:18:28 crit : Push Bullet does not have an API Key. Notifications will not be sent`
Push Bullet is configured, API key entered in secrets.json. Thoughts?
sparky600v
Meaford, ON
I have everything working perfectly on Linux other then I get an empty recording attached to my email.
From Logs: (I have since adjusted the silence detector)
24-09-14-08:09:05 info : Starting Web App
24-09-14-08:09:06 info : HTTP service started on 3000. http://localhost:3000
24-09-14-08:09:36 crit : Push Bullet does not have an API Key. Notifications will not be sent
24-09-14-08:09:38 info : Initializing Recording Worker Thread
24-09-14-08:09:34 info : Detector 524.6Hz ±2% [514.1080000000001Hz - 535.092Hz] Matches @ 525Hz. Count 5/6
24-09-14-08:09:34 info : Detector 524.6Hz ±2% [514.1080000000001Hz - 535.092Hz] Matches @ 525Hz. Count 6/6
24-09-14-08:09:34 info : Detector 496.8Hz ±2% [486.86400000000003Hz - 506.736Hz] Matches @ 495.5056179775281Hz. Count 5/6
24-09-14-08:09:34 info : Starting Recording 1726317156339.wav
24-09-14-08:09:34 info : Detector 496.8Hz ±2% [486.86400000000003Hz - 506.736Hz] Matches @ 495.5056179775281Hz. Count 6/6
24-09-14-08:09:34 alert : MULTI TONE MATCH: Detector West Grey Station 2 - Durham 524.6Hz,496.8Hz Detected. Match Averages: 525.024805102764Hz, 493.67041198501875Hz
24-09-14-08:09:34 info : All notifications for West Grey Station 2 - Durham have finished processing
24-09-14-08:09:34 info : Sending toneDetected to ws clients
24-09-14-08:09:35 info : Mic Instance Has Started
24-09-14-08:09:67 crit : Push Bullet does not have an API Key. Notifications will not be sent
24-09-14-08:09:69 info : Initializing Recording Worker Thread
24-09-14-08:09:34 warning : Detector Grey Highlands Station 1 Flesherton 496.8Hz,339.6Hz reset after matching 1 tone without getting full match. Time allowed for full match 4000ms
24-09-14-08:09:34 warning : Detector Grey Highlands Station 2 Markdale 496.8Hz,524.6Hz reset after matching 1 tone without getting full match. Time allowed for full match 4000ms
24-09-14-08:09:84 info : Detector 524.6Hz ±2% [514.1080000000001Hz - 535.092Hz] Matches @ 525Hz. Count 5/6
24-09-14-08:09:84 info : Detector 524.6Hz ±2% [514.1080000000001Hz - 535.092Hz] Matches @ 518.8235294117648Hz. Count 6/6
24-09-14-08:09:84 info : Detector 496.8Hz ±2% [486.86400000000003Hz - 506.736Hz] Matches @ 501.1363636363636Hz. Count 5/6
24-09-14-08:09:84 info : Starting Recording 1726317214843.wav
24-09-14-08:09:84 info : Detector 496.8Hz ±2% [486.86400000000003Hz - 506.736Hz] Matches @ 495.5056179775281Hz. Count 6/6
24-09-14-08:09:84 alert : MULTI TONE MATCH: Detector West Grey Station 2 - Durham 524.6Hz,496.8Hz Detected. Match Averages: 523.9705882352941Hz, 495.5473272046306Hz
24-09-14-08:09:85 info : All notifications for West Grey Station 2 - Durham have finished processing
24-09-14-08:09:85 info : Sending toneDetected to ws clients
24-09-14-08:09:86 info : Mic Instance Has Started
24-09-14-08:09:16 crit : Push Bullet does not have an API Key. Notifications will not be sent
24-09-14-08:09:18 info : Initializing Recording Worker Thread
24-09-14-08:09:84 warning : Detector Grey Highlands Station 1 Flesherton 496.8Hz,339.6Hz reset after matching 1 tone without getting full match. Time allowed for full match 4000ms
24-09-14-08:09:84 warning : Detector Grey Highlands Station 2 Markdale 496.8Hz,524.6Hz reset after matching 1 tone without getting full match. Time allowed for full match 4000ms
24-09-14-08:09:40 warning : Fail Safe End Recoding - Max Time Limit Reached after 90 seconds
24-09-14-08:09:41 info : Stopping Recording...
24-09-14-08:09:41 alert : Mic Instance Has STOPPED
24-09-14-08:09:41 info : Finished Recording
24-09-14-08:09:47 info : MP3 Processing finished. Saving 1726317156339.mp3
24-09-14-08:09:48 info : Sending 1x POST Recording email notifications
24-09-14-08:09:48 info : Sending email to _____, bcc: N/A. Subject: West Grey Station 2 Durham Page Received. Attach File: true
24-09-14-08:09:79 info : Email Notification Sent: Message ID <_____>
24-09-14-08:09:92 warning : Fail Safe End Recoding - Max Time Limit Reached after 90 seconds
24-09-14-08:09:92 info : Stopping Recording...
24-09-14-08:09:92 alert : Mic Instance Has STOPPED
24-09-14-08:09:92 info : Finished Recording
24-09-14-08:09:37 info : MP3 Processing finished. Saving 1726317214843.mp3
24-09-14-08:09:37 info : Sending 1x POST Recording email notifications
24-09-14-08:09:37 info : Sending email to _____, bcc: N/A. Subject: West Grey Station 2 Durham Page Received. Attach File: true
24-09-14-08:09:74 info : Email Notification Sent: Message ID <_____>
Any ideas?
NCFA
Plainfield Township, Pa
Firebuff880
Boynton Beach, FL
Anyone try Pushover for notifications? They have an app, works well. Notifications are pushed by Pushovers E-Mail Aliases. Your allowed 10,000 push notifications a month for free.
Have used them for many years on various endeavors with great results.
webstar22
Ontario, Canada
I use them. but keep in mind that each message to each user is counted on that 10,000
So 1 page to 100 users, = 100 notifications.
I've had to make 4 failover accounts, when one starts failing due to being over 10,000 it starts using #2, #3, #4 and so forth until they reset at the end of the month. N8N looks for the errors and does it automaticlly.
I personally moved to Telegram for the majority of my stuff
Firebuff880
Boynton Beach, FL
Or of compensate you can compensate them for excessive use. 4 * 10,000 = 40,000 so pay for 50,00 level at $200.00 per month.
Sending Notifications​
All Pushover users can send notifications to their own devices or to any other user's devices through our API, E-mail Gateway, or any Pushover-enabled app or service. Each user can send up to 10,000 messages per month for free. Users needing to send larger amounts of notifications can easily upgrade sending capacity through our website.
For high-volume applications that need to send more than 10,000 messages per month, additional capacity can be purchased from our website (10,000 for $50.00 USD, 25,000 for $115.00 USD, 50,000 for $200.00 USD, 100,000 for $300.00 USD, 500,000 for $1000.00 USD). Once an application uses its free allowance, subsequent messages will start deducting from its purchased reserve until the first of the next month. An application's purchased reserve will remain available until it has been completely used. Upgraded capacity is not transferable or refundable.
Echo4Thirty
Colorado Springs, CO
This is why we cant have nice things.
can you use this software on just a windows laptop without a rasberry PI?
FD Tone Notify has been tested over the past several weeks and released with binaries for Windows, Linux, and for the Raspberry Pi (ARMv7). In the near future Raspberry Pi starter kits will be available with the software pre-loaded with a basic configuration.
You can read more about the Launch Notes on the blog.
Project Website: FD Tone Notify – Dispatch Tone Notification Software for Fire Departments and Enthusiasts
GitHub: kjdElectronics/fd-tone-notify
Release Page: Releases · kjdElectronics/fd-tone-notify
Documentation
License
mckinscan
Spartanburg sc
Hi Kevin,
I download the SOX and add the Vailables and then i download the Zip of your FD Tone program and i can't find the right file to run it to set it up when i unzip the file it unzip as fd-tone-notify-main and i don't see any flle called fd-tone-notify.exe to run it i'm running windows 10 64 also does the email part used the new oauth 2.0 since most all email providers has turn off the basic auth that the old TWOTONE DECT used to send the email. thanks
kevind963
Hi Kevin,
It seems like you downloaded the source code opposed to the Release from the Releases section. You will see many less files and that exe.
Email can be configured for free for personal use via Brevo (see Readme). This service allows sending emails without needing to worry about complex authentication strategies.
mckinscan
Spartanburg sc
ok thanks you
hruskacha
Muskegon
"fd-tone-notify --detect-from-files" gives an error. It says that "--detect-from-files" is an unknown option...
kevind963
That option is only available when running from source. The pre-built binary executables do not include that option.
This option is the precursor to some other new features as well.
hruskacha
Muskegon
Is it possible to build the source for windows or is that just a Linux thing?
kevind963
