I'm seriously thinking about getting this scanner. But have a question regarding this feature:
"Control Channel Data Output - allows the analysis of control channel data without the need to perform invasive modifications to the scanner"
I've seen pictures of the unit, but I don't see an output jack. How does one access this feature? How well does it work?
OK, and what software is used?
so all programs (like trunker) can be used then it seems?
Straight through the serial cable Pro96com works for P25 systems. Trunk88 works great on P16 systems. Unitrunker does NOT work even though it is listed in the program itself.
Marshall KE4ZNR
Ok, I have read all 10 pages of this thread.. What I'm still trying to figure out is..Is the BCD996XT the successor of the 996T?
I haven't seen a side by side comparison.
Is the 996XT The new Uniden Flagship? Thanks
Marshall KE4ZNR
I downloaded the Pro96com and tried it on my 996XT but I guess it does not work on it. I could not get it to do anything.
i was useing front port and was trying it on IL Starcom 21
Click in the Edit, then Decode Configuration, and select BEDSIT (because there is no choice for BEDSIT. Check your COM port and baud rate while your there. Is the IL Starcom 21 system 9600 baud?
