Eric61
I'm using DSD+ Fastlane v2.39 and FMP24 v2.19 to trunk-track a 4 frequency Cap+ system. Voice channel tuning/reception is with a NooElec SDR dongle. Everything works great with one exception; I don't get very good voice decode- probably about 80%. However, if I park SDR# on one of the same voice channels and route the signal to DSD+ through VB Audio cable, voice decode is near 100%. I have tried adjusting gain and bandwidth in FMP24 with no improvement. Also tried minimizing FMP24 (as was suggested in another post) with no change, but I doubt CPU processing power is the issue.
Since the dongle is tuning the voice channel in both instances, shouldn't the decode ability/rate be the same? The only other factor is the use of a scanner to monitor the control channel and tell FMP24 the frequency to tune, but once tuned, shouldn't the voice decode be comparible to using SDR sharp to feed DSDplus?
I have also performed fine tuning of DSD+ and found the defaults give the best decode rate. At this point I'm not sure what else to try and am open to any suggestions.
Thanks,
Eric
Thanks,
Eric
