DSDPlus DSD+ FL 2.505 released
cg
Connecticut
I believe some of my local users that have Control Stations that show aliases use a different brand control station than the subscribers Kenwood mobiles and portables I think.
cg
Connecticut
Use caution if you haven't updated. Not going to v2.506 from 2.505 may cause the OTA decoding to shut off with only a 2 line warning that will scroll away.
CanesFan95
Was Homeboys-Scanna
Banned
FL
Yeah, looks like it's now disabled by default and you gotta turn it on now.
Reconrider
Inside the Galaxy
Radio Galaxy
Just went through this with my buddy, took us a good 30 minutes to figure out what caused it
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Can I get a translation of that?
Cut off the last portion of that (about talkgroups).
I'm guessing the 601 aliases are user-created aliases in the .radios file
The MotOTA, MotClr and MotPrt are the ones keeping track of OTA alias activity.
Better?
dave3825
Suffolk County NY
Then after your paid up and running with FastLane, you can download the alias stats file which would download into your DSDPlus directory.
ESF-12
Edmonton, Alberta
I don't get the HIGHPPMerr, at least what it's supposed to be adjusted to, or figure out what the value should be. I can increase and decrease the value and it's always displaying HIGHPPMerr... and I don't know how to set it for auto. Monitoring a p25 ph1 system.
mtindor
FMP24 PRO USER
Are you using 2.505 DSDPlus Fast Lane? If not, then this probably isn't the best thread to post in. You should post a new thread with your issue or tag on to one of the threads with already discussing the version you are on.
Are you running Fast Lane at all?
dave3825
Suffolk County NY
He would have to be or he would not be seeing it.
DSD+ 2.505
Decoding of a few more P25 control channel messages has been added.
Added a "HighPPMerr" display to the event log and channel activity window titles.
This text indicates that the PPM correction in FMPA/FMPP/FMP24 is not adjusted correctly.
Adjust PPM value in FMPx with p/P keys to eliminate the error display.
mtindor
FMP24 PRO USER
The value I think should be as low as possible. You have to have focus on FMP24. Then use p/P to adjust up/down to get the lowest value.
ESF-12
Edmonton, Alberta
Thanks for the tip!
I can so low and/or so high that it loses connection to the control channel and still have HIGHPPMERR. Looking at the FMP24 window I can watch the signal drift either way as I adjust it, I just don't know what I'm looking for to get that correct value. Oddly enough though, HIGHPPMerr isn't always displayed, sometimes even when a monitored TG is coming through, it just shows up sometimes.
And of course it won't let me attach a photo...
dave3825
Suffolk County NY
When you focus on fmp24, hit the ? And look in some of the other windows open it gives you options that work with Fmp24. Believe it’s a/A when focused.
How many dongles are you using, 1 or 2? If 2 it can be tricky to get the ppm set if there is not many voice calls. If one dongle, fire up sdr# and tune to the control channel. Then play with the ppm to get the signal centered the best you can. Then remember that value which will be either a positive or negative value and apply it to Fmp24
If two dongles and you know which is which, do the same and set that ppm on that dongle.
If your on a pc use windows snipping tool to capture screen shots and paste them right into your message.
ESF-12
Edmonton, Alberta
Apparently, centering is all I had to do! Thanks. And toggle off 'a' on two instance. (running three separate instances of DSD+ one dongle each.) I didn't expect each to need a slightly different value. Thanks again.
dave3825
Suffolk County NY
Each will need its own ppm set. You also have the gain maxed out. Focus on each instance of Fmp24 and hit g to lower the gain
