DSDPlus DSD+ FL 2.505 released
CanesFan95
Was Homeboys-Scanna
Banned
FL
Letting my DSD+ run since yesterday and am pleased to see the progress being made, really like the new feature of OTA alias decoding. This is a great tool for trying to figure out who is using encrypted TGs. Over 1100 decodes on my system so far and quickly growing.
Yeah, agreed. This is a cool feature and appreciate the DSD+ updates. And thanks to mtindor for all those good explanations and answering questions. (y)
bravo14
Polk County FL
TG & RID? No system spits out TG names. It covered RIDs. It was Cary/Wake County
Okay TY. I wasn't too sure if it did both. None of my systems here doesn't spit out the RID Alias guessing the system(s) don't do OTA alias info.
bravo14
Polk County FL
SLERS doesn't either?
Only SLERS in Polk Cnty FL is Edacs no P25 yet. The 3 systems I have tried yesterday are below. From 2am to 1030am I left Duke Energy run and no new RID showed up and no new TG popped up.
Lakeland Phase ll Lakeland City Services Trunking System, Lakeland, Florida
Polk County Phase l Polk, Hardee, Highlands, DeSoto Counties Public Safety Trunking System, Regional, Florida
Duke Energy Ft Meade site Duke Energy P25 Trunking System, Various, Multi-State
For those in NC, a clarification about the Viper decodes, the Cary/Wake System using part of the VIPER system for County Sheriff inmate movements and a few other things, they also have set up the radios on the Cary/Wake system so the RIDs match VIPER RIDs.
So far the ONLY decodes of RIDs I got on the Viper have been Cary/Wake system radios. I do not believe VIPER has any OTA aliases of their own.
bravo14
Polk County FL
I went to a spot 20 mints from me and try to get Hillsborough Cnty P25 and seems both of their sites control channels are offline and it switch from 700 to 164. I was trying to see if they do OTA guess I'll try later tonight when I'm in that cnty.
dave3825
Suffolk County NY
Db shows 4 sites that are all 7/800. Online nodes are running. Where and what is switching to 164?
bravo14
Polk County FL
DsdPlus v205
Site 1
769.28125 switched over to 162.88125
Site 2
770.58125 switched over to 164.18125
Sds100 both sites couldn't lock on the 700 Cntl Ch.
I went back to a older DSDPlus and showed the samething as above.
cg
Connecticut
DsdPlus v205
way beyond v205, did you mean 2.505?
If DSDPlus and SDS radio both dropped out, that might indicate a system issue or common reception issue such as local interference.
Do you have hunt for lost control channel turned on? Do you have all the control channels shown in DSDPlus entered in the SDS? If the system only shows the active control channel, the system may allow any system channel to become the CC and you would need to enter all system channels in.
Click rebuild bandplan and see if there are any VHF entries in the list that shows up.
bravo14
Polk County FL
The dsdplus does have hunt for lost cntrl ch. I think the system is having a issue.
dave3825
Suffolk County NY
DsdPlus v205
Site 1
Site 2
I had something similar yesterday (but only with DSDPlus) and it turned out to be something in the dsdplus.p25data file. I tried rebuilding a few times and it did not fix the issue. I ended up removing the cc data for that system and saved. Then tuned to the active cc and it re-wrote the data back. All good now.
Hunt for lost control channel reads the control channel data from the p25 datafile. If there is no vhf associated with the system, it should not be switching there. It should only cycle thru cc and scc freqs.
bravo14
Polk County FL
I remvoed all 4 sites and the p25 data file and restarted the dsdplus and no luck on it. That's when I went back one on the dsdplus and same problem.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
DsdPlus v205
Site 1
Site 2
Park DSDPlus on one of the supposed control channels, when system information shows up and/or when somethign change, take a screenshot and post it. A screenshot is worth a thousand words.
How would you know if 769.28125 switched over to 162.88125 if there was no control channel on 769.28125 to begin wtih
How would you know if 770.58125 switched over to 164.18125 if there was no control channel on 770.58125 to begin with
Again, screenshots can help others understand the things you are trying to describe much better than having them read your description of what is happening.
dave3825
Suffolk County NY
For me, after picking a 700mhz site with site loader, it would go to the cc, then FMP24 would show it was on 170.00.
bravo14
Polk County FL
When I plug the site 1 or 2 control channel in it drops that freq out than switches to the vhf by it self. Even with sold signal on the 700. I never had that problem with other systems on the road.
