I’m not sure about FRS since the rule changes, but I did testing years ago and a half watt FRS couldn’t touch a MURS radio. It also depends on what you are testing. Revitis now makes a bubble pack MURS radio with fixed antenna. That would probably be a fair comparison to a bubble pack fixes antenna FRS radio with the new 2 watt limit (on shared channels). I still think the MURS with 2 watt would blow away the half watt FRS in most situations. Inside of buildings, FRS may have an edge. Where MURS shines is in mobile and base applications. I used several of the old Radio Shack, 19-1210 mobiles peaked up to exactly 2 watts (they are capable of doing 5 watts on business part 90, but would limit themselves to 1 watt on the MURS frequencies. The blue pot has to be turned to increase it to 2 watts. If you don’t have the right equipment, don’t do it or you may exceed limits). Anyway, you will want to buy a good antenna. For mobile units a good MaxRad or Laird NMO mount style was the way to go. Mag mounts often get pinched and don’t perform as well, a roof mount is usually the best, if your other half won’t kill you for drilling holes in the car. If you buy a retired police car it already has the holes cut sometimes. I actually bought my old squad car from the Fire/Rescue (I was EMS Chief) it was a nice Interceptor....drove it for years. I preferred the 5/8th wave antenna on vehicles as I am mostly in the rural areas and hey seems to go a bit further than 1/4 wave. If you are in a different environment, you may need to experiment. The base station was just a dingo ranger made by cushcraft. It sat at 60 feet on a well grounded tower and mast. I used LMR400 coax cable. Again a Radio Shack 19-1210. I was able to broadcast over most of our rescue squads revised district (other departments kept encroaching, eventually we had nothing). We had a few more dead spots than the 50 watt department radios and definitely less range as we could talk to dispatch even when the repeater was down on the 50 watters. I’d say about 15 miles on the “wimpy” MURS base to mobile. Maybe 5-7 miles mobile to mobile. That is another area where MURS crushes FRS is vehicle to vehicle. That detachable antenna is a real game changer. Also MAKE SURE your SWRs are nice and low, have a good ground and don’t chinch on coax cable. Licensed GMRS with real radios (not bubble packs) blows away MURS, because it also has detachable antennas, up to 50 watts of power AND repeaters! MURS is great and I’ll always be a fan, but I upgraded to GMRS so I could run repeaters and power, but MURS beats FRS hands down.
