Greater Cleveland Radio Communication Network
scannerjt
strongsville ohio
Tried all antennas in the tool box at least 10 plus diamond d-130 ,antennacraft st2,and tv hd . This is driving me crazy,been a fan of the cleveland system since 1965 in the 38 to 40 MHz days. Sometimes it gets through but not to often.I called uniden about the problem tech guy about told me good luck because of the LSM. Well thank radio reference for the live audio feed until I can get it together.
Since it's a silmulcast system, any site you can receive will have all the traffic. Instead of increasing antenna capacity, try reducing it. I found I don't do well with an attic antenna but with back of set or other lower antenna it's fine. Turn on attenuator...etc...
parmajake
Parma,ohio44130
Greater Cleveland system
Im in strongsville whitney rd almost in roylaton and I can not pickup the greater cleveland system. I have tried everything. I think Im a victim of LSM. Get 5 bars on signal and message finding control channel. I might try a Yagi directional as a last resort. Anyone have a suggestion besides move down to the corner of w-130 th.
I too live by your area(tri-c area in Parma)And this system reception is poor at best.I see now that another site is operational in N.Royalton in York Alpha pkwy Took a drive there w/the pro-106 and was able to hear how nice the system can be heard.These simucast systems can be a real downer if your not close to a tower site.The 700mhz Marcs IP system is better here though not what I call good.I hope to hell Parma doesn't go to this but I thinking that might happen eventually.I wish that the Greater Cleveland system might add/aquire another tower site around here when some of these other radio systems go away
lite SWRCN,etc.Not sure what really happens to these once abandoned like Parma's old EDAC,etc...
tylerwatt12
Cleveland
Heard 56290 today, It's a fire dept. One of the Olmsteads, can't figure out which.
I heard a mutual aid call to Columbia Station.
k8zgw
Macedonia Ohio
reseption of Cleveland system
I just happen to be in "just the right spot" and have no trouble with The Cleveland System,
as well as Lake County and the Marcs-IP.
I am half way between the Cleveland east tower ( Chardon Rd.) and the Lake County
West site ( E.305 and Euclid Ave.)
Listening to all three of these systems on a GRE 800 and "old" Marcs on a GRE 600.
The 800 is using the "stock" rubber duck, while the 600 is on a "high band" mobile
antenna at about 25 feet ( trying to hear Geauga system.
My interest is FIRE, I don't much care about police ( I listen to Euclid police and fire
on their 420 systems, I hope they don't change - it works too good)
My major problem is trying to keep up with the Talk Group changes.
and keeping up with any control channel changes.
As Red Azelia said, it's not always about gain, but directivity, find a narrow beam-width
low gain antenna. Not an easy thing to do, this is something you may have to build yourself.
Take a look at a corner reflector for 800 Mhz, You can't avoid some gain, but an antenna
attenuator should solve that problem. It's worth a try, you can build it yourself.
Google is your friend
Don
tonya
Bratenahl Ohio
Misc TG's
Picked up a couple of new TG's. Not enought to submit but I thought I would put it out there anyway for others to monitor.
56070-Sounded like Cleveland EMS to ARFF at Hopkins.
56309-Middleburg Hts-Tac-1
Also got traffic on 56290 and 56291. Was Westshore FD traffic (N. Ridgeville-Columbia station) but I'm not sure that was one the Cleveland system. I deleted too fast.
tylerwatt12
Cleveland
This is what I just submitted after confirming in my DB:
56309 Middleburg Heights Police TAC1
56290 Olmstead Falls Fireground 1
56291 Olmstead TWP Fireground 1
I didn't submit 56070 yet but it sounds like they're calling "station 1" dispatch, they have a north and south. It is ARFF, and yesterday a call was made from CPD to ARFF
They also called it ARFF3
tylerwatt12
Cleveland
Talkgroups that are very active and need identification/confirmation
56190 water, need more info
56245 possibly city hall, need more info
56193 water, need more info
56245 Cleveland parks, need more info
56059 KCLE Airfield maint 3
56251 Cleveland maint, need more info
56430 300 calls, all appear to be encrypted
56247 Parks/maint, need more info
56174 Cleveland water, need more info
56361 Sounds like a rec center, need more info
56587 Parking meter readers
I don't know how much info to gather before it's okay to send
budevans
Cleveland, Ohio
TG56509 Strongsville Fitness Dept
Monitored several conversations today on TG56509 (radio id's 1877xxx). References have been made to.. Fitness, the Gym and Men's Locker Room.
When I Googled Fitness for Strongsville I came up with the following link to the Strongsville Fitness Department.
The City of Strongsville
Over the last month I've monitored traffic with radio id's of 1877xxx (Strongsville's) on the following TG's.
56507 (?) (28 hits)
56509 (Fitness Dept?) (12+ hits)
56510 (Service Dept) (1600+ hits)
56512 (?) (8 hits)
56516 (?) (1 hits)
56528 (?) (2 hits)
budevans
Cleveland, Ohio
TG56059 Hopkins Field 3
TG56059 is Field 3, I monitored two conversations this week on this TG and both started with a call for Field 3. The rr database shows Airfield Maintenance 1 & 2 for TG's 56057 & 56058. TG56059 should be submitted as Airfield Maintenance 3.
Regarding 56587, it is a second TG for the Cleveland Parking Garage & Parking Meter Readers group. There is very little traffic on this TG.
Regarding the Water Department TG's (56180 - 56198) it's tough to get specifics for these TG's. Only a handful like Water Turn Off and Water Permits have specific labels.
k8zgw
Macedonia Ohio
TG's for west suburbs fire
I would like to be sure that I have these correct, and
that I didn't miss any:
56286 Berea FG1?
56287 Brook Park Fireground 1
56288 Middleburg Heights Fireground 1
56289 North Royalton Fireground 1
56290 Olmsted Falls FG1?
56291 Olmsted Twp FG1?
56292 Parma Heights FG1?
56293 Strongsville FG1?
56294 Berea FG2?
56295 Brook Park FG2?
56296 Middleburg Heights FG2?
56297 North Royalton Fireground 2
56298 Olmsted Falls FG2?
56299 Olmsted Twp FG2?
56300 Parma Heights FG2?
56301 Strongsville FG2?
56344 Berea FD Dsp
56367 BrkPk FD Dsp
56398 MdbgHts FD
56421 NRoyalFD Dsp
56478 Olmsted FD Dsp
56494 P Hts FD Dsp
ALSO, have anyone had success listening to the "CCRCN"
with a gre600 ??
Don
GCRCN down?
What happented to the system? I haven't got a control channel and no hits since 7 PM.
I normally get a rssi of about 700 off of Beachwood. Beachwood must be in trouble. I have two systems Cleveburg and eveyone else on GCRCN and I get nada.
OK got a couple of hits from CHMA PD and Cleveland utilities. Must be too cold for crime. :)
