prcguy
- Joined
- Jun 30, 2006
- Messages
- 17,855
- Reaction score
- 13,355
One or two models of older SINCGARS transceivers could have the crypto removed and an impossible to find bypass module installed or some internal surgery, but that is the only modern type green mil radio I know of where you can remove crypto and still have a working radio. There are lots of pre 1985 vintage radios with removable crypto but we have been talking current stuff, which is not going to work out.
It seems so, I was told that some older radios, even after removing the crypto module, would work in PT Mode, but newer radios like PRCs-117F, 117G, 152/A, 150, 148, 1523E/F, won't work even in PT mode after removing the crypto module. The only alternative is to have export versions of these radios. As I researched a bit, perhaps it will help anyone in anything. I am rather pretty sure about these info. So, while having operating PRC-117F is of course illegal, such with removed crypto module is fine to have. Such appear from time to time as surplus, but then it can be used only as an object to put on the shelf, to admire for some collectors, or for some military reenactments. I am also pretty sure that the crypto module and other ones are inside the radio, you have access from rear after removing rear panel. As for KDU, it is needed to put crypto inside, it is for display, but nothing crypto inside. What is interesting, radio+KDU, to which crypto data are put, become 'linked forever', so only through the same KDU, you can put crypto data, and use the radio in all modes. When you have KDU which is not from a given radio, you can load crypto into the radio, but with this 'not assigned' KDU, only PT mode will work, of course crypto module is not taken. As someone was asking, never seen on EBAY DEMIL radio, software(nothing surprising), but some accessories, like cables, data one, these for KDU to work in remote mode, antenna, battery cover, handsets, spekaer, they appear, as someone can always have by chance from some source export version of 117F, so RF-5800M-MP.
