Also you do not have to use the band plan with the 996t just the 996xt uniden
Scott, Please check this out.
Updating the Firmware in Uniden DMA Scanners - The RadioReference Wiki
You need firmware 3.0.2 according to the article for your 996t. Rebanding support started with version 3 of the firmware for the 996t. The article has links to more information including the uniden site.
I hope this does the trick. Let us know.
73 Richard W4MCD
Okay.... My scanner HAS been updated to 3.02.00... All old control channels were wiped, and then I added all new rebanded control channles..... I tried setting it up as "Motorola Rebanded" and it gets hung up on some frequency that doesn't even exist.... If I use regular old Motorola Type II, it does nothing, but stay locked on the local CC...
I am attempting to reprogram my Uniden BCDE96T. Its firmware version is 3.02.02
The Edit Band Plan menu requires me to select from 16 field (0-9 and A-E). Each field requires me to input base frequency and spacing. I see no way to input the Lo, High, Step and Offset information you provided.
Can you help?
Thank you.
