I'm looking for a small compact cb radio to fit in my 2017 Jeep GC.
Kingwood, WV
I bought a Cobra 19 Ultra V, Ultra-Compactis the absolute perfect size but from what I'm hearing that unti is weak and if cannot be tuned or peaked..what would be the best small foot print radio I could go to so I could actually get it tuned and get some power from it? Thanks in advance.
vagrant
ker-muhj-uhn
California
The OP must be from the future since they feel they need a brand new CB radio "tuned and peaked", although I seemed to have heard that phrase quite often in the past ;) Anyways, most any CB radio will be fine. One compact solution is the Midland 75-822 which I occasionally use. Perhaps that mic hole on the radio you have could be bigger, if your audio is low. Otherwise, leave it alone.
What you really should look at is the antenna and mounting location. I recommend a 102" steel whip antenna on a spring mount located directly center of your roof. Anything less than that and I hope you enjoy even more compromise. A proper antenna not only helps with transmit, but receive as well. Still, if you only plan on communicating with another operator at a distance of 1000 yards or less you can probably get away with a compromised antenna in a compromised location.
Kingwood, WV
Just curious, how'd you get a jeep that won't be built for nearly 900 years? You said you have a 2917 jeep :)
Yeah horrible type I don't know how to fix
Yeah I have a great antenna I didn't figure these new unit's could have there ears and modulation tuned
he is looking for one of these...
I have a few if those
I’m not familiar with all of the new radios, but the old Uniden 510 or 520 absolutely couldn’t be beaten for their size.
As I recall those uniden can have there modulation and what not sit to 15-17watts swing that would be suffice
Kingwood, WV
Don't know how small you need but check out the President line of CB's. The President Johnny III is small and durable (made for jeeps, etc.).
I'll most definitely check them out I've only owned one president it was we a Lincoln 1+2 10,12 meters it was a great radio
2IR473
The Radioddity CS-47 AM/FM CB radio might be worth looking at…
CS-47
This radio is capable of expanding it’s frequency coverage, as well as the ability to have additional transmit power output.
slowmover
Fort Worth
Any choice needs integrated NRC as obsolete without. Several small size choices. Combine with KL203. Extension speaker recommended.
slowmover
Fort Worth
Anytone 6666, small, but 70w PEP output. Great modulated audio with just the mic it comes with. It is powered by the radio. A 15A ciggie plug would be fine.
Lacks NRC. Would need WEST MOUNTAIN RADIO CLEARSPEECH DSP Speaker.
Power should always be dedicated.
Not to vehicle wiring.
6666 not “small” as with some offerings. Over halfway to best choice (AT 5555N2 / QT60).
But as with the latter both are full-featured, but only QT60 with necessary NRC.
IMO:
An AM only radio? No SSB? No NRC?
Avoid
I was leaving ABQ one morning headed east up into Tijeras Pass on IH40 and was losing the other driver with whom I was speaking on AM at about 11-miles LOS. We switched to upper Sideband and I was 27-miles away and past a major bend 3,000-ft above him before he lost me for good.
I could still hear him past the point he could hear me (NRC).
Plan for the day roadgoing comms matter.
