Kenwood NX 5300 problem and question.
PGHSCANNERWACKER1
Pittsburgh pa
My department has the Kenwood NX 5300 I program the radios we are trying to figure out how to set up the audio voice announcement for every channel when we change channels it announces what channel it is on? Anything will help.
Vern
Union County, GA
You can use the "Standard" names "Zone One", "Channel One" by going into KPG-D1N, Optional Features, Optional Features-1, Voice Announcement, and find the section for Voice Announcement Type. Change drop-down box from None to Standard. Then just below that, put a check in the box for "Zone-Channel Guide". That should turn on the standard voice labels for Zones/Channels. If you want to make your own custom names for Zones and Channels, that requires using a microphone to make a voice clip file for each Zone & Channel name and storing them in the Audio Library section (Under TOOLS menu), then going back into the Voice Announcement Type drop-down box and choosing "User Programmable" instead of "Standard". You'll have to go edit each Zone (Zone Edit) and Channel to link each to its respective voice clip file. I think that's it. Good luck.
PGHSCANNERWACKER1
Pittsburgh pa
Thank you so much for the help
