prcguy
You won’t notice any difference between AES and ADP.
Just curious, what frequency or frequencies are you testing on?
It doesn't matter, if you have it, it must be tested. Like if you came across a full auto weapon you must test it in the garage or basement. Or finding a shoulder fired rocket launcher, you must point it down the alley and see what happens. Or a friend brings by a 300mph vehicle, you must venture out on the freeway late and night and see if it really goes that fast. Even if the experience is no different than 100mph.
Test frequency will be in the alley, late at night.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
RX only. It is a VHF MURS frequency I set to P25. Just wanted to see what it looks like.
That radio is not type accepted for MURS operation. There is absolutely nowhere you can use any of your radios without a license. And programming frequencies into a transmitter for which you are not authorized violates 47 CFR § 90.427 (b).
Again, can't follow the rules...
Oh and we're educating the teenage CEO of an LMR business on top of it.
p25p2nas
Did you read RX only????
tweiss3
Is it time for Coffee?
Ohio
What will RX only do for you when there isn't an encrypted transmitter for you to listen to? Also, still violation of 47 CFR § 90.427 (b), even if RX only.
p25p2nas
Thank you for this info, I will remove it now.
