Marine Radios That Will Accept Non Marine Frequencies
majoco
Stirrer
New Zealand
As far as I recall, going back to the 60's when I was a marine radio officer, VHF radios had to be 'idiot proof', so that they could be used in an emergency by any unskilled person on the bridge of a ship. One switch for Ch.16 and a fixed squelch and volume so that it could not be muted. You could select any channel number, but not frequencies, you didn't need to know anything, the coast radio station would tell you the working channel to switch to, usually 21 or 22. No need for callsigns, the call was the ship name. Certainly no out-of-band selection.
Spec
South Carolina
I'm curious while not having used the 400 if it is capable of repeater use on 2 mtrs.
AA4TX
IONAFLXARS0
Yes it is, up to 40 different memory slots. You just have to enter both transmit and receive frequencies, instead of a receive and offset, like you do for an amateur radio. It supports PL and DPL as well, both encode and decode.
John
AA4TX
JASII
Memory Capacity
I got side tracked by other projects, but now that spring is getting close, I am getting interested in this again. Two questions:
-Does the Standard Horizon HX400, at 40, have the highest channel capacity for land mobile channels?
-Are there any marine radio portables that have Bluetooth capability yet?
iMONITOR
Silent Key
S.E. Michigan
Is the software for programming the Standard Horizon HX400 readily available?
Standard Horizon | Yaesu YCE13 Programming Software
For radios: HX400 & HX380 with firmware v2.00 or later
https://quality2wayradios.com/store/Standard-Horizon-YCE13-Programming-Software
NOTE: This software is for the latest version of these radios. Your radio must be at firmware version v2.00 or later. If your radio was purchased before 4/24/2017 then this version may not work for your radio.
prcguy
