The regional EMRCs can patch any unit to any receiving hospital over a variety of Med channels, both conventional and talkgroups. This includes the helicopter channels, 7AIRMED, HELIMED1, and 47.66, to name a few. The regional EMRCs can cross-patch between each other. Here are some screen shots of our legacy patching system that we wrote 34 years ago and we are soon to replace with an updated system.The Helimed tg would be used for consults when enroute to UMST, although most consults occur on the ground via the local systems or UHF. Conceivably 7648 could be patched into Medstar, Children's, or the other regional trauma centers. TBH, I don't think I've ever heard Helimed in use on FIRST. I occasionally hear SYSCOM on 7640 and the 700 A-G channels. MIEMSS is in the middle of a major networking upgrade, so perhaps it might become more common with better connectivity with more facilities.
Could you explain how 7AG60 works and is it something I should replace 44.74 with ? Thank youThe regional EMRCs can patch any unit to any receiving hospital over a variety of Med channels, both conventional and talkgroups. This includes the helicopter channels, 7AIRMED, HELIMED1, and 47.66, to name a few. The regional EMRCs can cross-patch between each other. Here are some screen shots of our legacy patching system that we wrote 34 years ago and we are soon to replace with an updated system.
For those who wonder, we have 44.74, 7AG60, and SYSCOM TG patched together at all times for situational awareness of all medivac aircraft. The 44.74 uses a JPS SNV-12 for voting and transmitter steering. 7AG60 is voted but manually steered since Motorola does not support transmitter steering.....
It only shows type M(obile) and I never receive it from south central PA, so you may be right.Thank you, so I’m assuming the is just a simplex frequency and isn’t something that is repeater based and will only hear something if it’s really close and wouldn’t hear SYSCOM all the time ?
That sounds like SYSCOM. Helimed would have PT. info being reported to the receiving hospital they are flying too.I have heard the Helimed on the 1st system a couple of times while monitoring the montgomery site with my portable. One time it was Trooper 7 enroute to Trooper 1 HQ for fuel then off to Philly PA for training then I was able to catch it 6hrs later coming back from PA to Trooper 1 for fuel then on to southern MD to go home.
There are several voted ground stations scattered throughout the state, and mobile radios in the aircraft. The EMRC / SYSCOM communicators can determine which ground station has the best receive quality and use that site to transmit to the aircraft. What would be interesting is monitoring the input (mobile transmit) frequency 800.631250 to see if it is used for duplex or if 7AG60 is used in simplex mode. For clarity purposes, 7AG60 is not part of the FIRST TRS.Thank you, so I’m assuming the is just a simplex frequency and isn’t something that is repeater based and will only hear something if it’s really close and wouldn’t hear SYSCOM all the time ?
7AG60 was developed to be utilized by helicopters that no longer have lowband capability and don't qualify to be on the Maryland FiRST radio system, such as commercial helicopters. 7AG60 and 7AGMED are part of independent six site voted systems with manual transmitter site selection. Originally this was planned to be the channel that replaced 44.74 but with proper programming, the MSP helicopters are able to leverage the Maryland FiRST trunked radio system's talkgroups (SYSCOM and HELIMED1 TGs). It is anticipated, that use of 44.74 will go away once the Maryland State Police have replaced their non-Phase 2 compliant radios, which was funded this last legislative session, and once 44.74 no longer becomes needed. Keep in mind that the MSP medivac program extends 30 miles outside of Maryland's borders so a lot depends on if 44.74 is still needed to reach these areas.Could you explain how 7AG60 works and is it something I should replace 44.74 with ? Thank you
The receive signal from all 6 sites are voted and only the manually selected site would be transmitted on. The base stations are not simplex.Thank you, so I’m assuming the is just a simplex frequency and isn’t something that is repeater based and will only hear something if it’s really close and wouldn’t hear SYSCOM all the time ?
