apex31
WAWA21 flt on ACY Ground taxiing to RWY13 for their second week of Night Ops. Ground asked if they knew if the COSMICs were still launching tonight, then asked if they'll be coming from the Guard ramp or the Alert Hangars. The Devils are making the most of this ideal weather, probably will have at least six jets up tonight.
WAWA flt is up with another cell. Sounds like ESCO/WESCO (?) -11 but not sure.
1940 - COSMIC01 launching
TerryPavlick
Wallingford PA Villas NJ
298.600 Air / Air
COSMIC on 260.900
Button 18 = 298.600
Button 17 = 255.000 possibly
376.175 active with Air Air
1819- Unid acft (no call noted-nothing on ADS-B) working Echo Control (262.95).
Copied also sometimes fairly strong.. Sounded like Starlight-1 or something like that.
I think is test GLF5 N99NG Northrop Grumman which came up from Melbourne Fla.. Snowbird? LOL
Landing at BWI last Fall..
AE1179 02-1107 E21107,EVAC076 C17 ACARS messages show they seem to be having a problem connecting to a datalink...
TIMESTAMP: 23:53:32 MESSAGE DATA:
[FREETEXT]
ITS WORKING NOW BUT DONT YOU HAVE TO TYPE IN A CALL SIGN AND YOUR REGISTRATION
WHEN LOGGING ON TO DATALINK. OR IS IT PRE PROGRAMMED.
TIMESTAMP: 00:02:47 MESSAGE DATA:
[FREETEXT]
I CAN OVERRIDE A REGISTRATION MISMATCH. BUT WHEN THE CALLSIGN DOESNT MATCH THE FLIGHT PLAN THIS WAS THE ONLY THING I COULD DO TO FORCE A CONNECTION
TIMESTAMP: 00:07:04 MESSAGE DATA:
[FREETEXT]
JUST CONTINUE ON FP WITH THE NEW CALLSIGN. I GUESS IF YOU FLY THIS PLANE BACK EXPECT A SIMILAR ISSUE
GriffissSpotter
Central NY/Western NY
1212 - DECOY 99 (C-17A/94-0070) cleared contact by STEEL 64 (KC-135R/59-1467) on AR-206L prim (235.100)
*Advises they will be doing a practice emergency separation*
1221 - BISON 81 *# not confirmed* (KC-135R/58-0038) boom radio check with FLOOD31 (C-17A/04-4132) on AR-206H prim (348.900)
1225 - Picked up a short transmission on 234.800, sounded like fighters
Was able to snap some pictures of the AR-206 action earlier today. Not the best photos as they were shot through a window and the aircraft were right near the sun!:ROFLMAO:
STEEL 64 and DECOY 99 on AR-206L
BISON 81 and FLOOD 31 on AR-206H
Anyone in New England area have a list of active frequencies? New to scanning mil-air.
Read through the past few years of these posts and you'll find lots of them, you can also look in the RR database for bases near you and check the FAA UHF frequencies on charts near you. Those are the best suggestions, people usually put together their own lists from searching and logging.
AirScan
Your previous posts indicate you are in Central Vermont. If that's the case I posted a list over on another thread that might help you out.
Mil Air frequencies near Albany NY
Add 324.600 to that list, which is AR204, runs through that area.
You should get good reception of the VT ANG F-35s out of BTV. I'd be interested in what you can hear.
Hill AFB Utah bringing everything but the kitchen sink and maybe that too... 😊
I don't think this is a short deployment 😉
RCH-286 C-17 #08-8201 HIF to PSM
RCH-544 C-17 #09-9211 HIF to ETAR.
RCH-247 C-17 #10-0219 HIF to PSM.
RCH-235 C-17 #01-0186 KDOV to HIF.
GOLD tankers standing by..
paradiver
Middle River, MD
Maybe this will help you this is my working files in Excel format. As you can see I am actively reworking them.
  • Scanner Database Map Aviation.zip
  • Scanner Database Map Military.zip
  • Scanner Database Map Aviation ZNY New York ATC.zip
  • Scanner Database Map Aviation NCR Airspace.zip
