Looks like KC-46 MEDUSA-85 coming East towards Va Beach area with some chicks it picked up
near St Louis. You can see how it jogged North and dropped down to FL-260. Oceana F/18's from depot repair?
Kind of odd doing this at night. Maybe the broken F-22's Demo from West Coast airshow?
RadioFreq
Burlington, CT
Langley FF Demo F-22's (RAPTOR-1) had bad time at this past weekend's Miramar airshow.
On two days ended up cutting demo short and towing them back. Friday show never got off the ground.
Maybe the old demos are getting tired and use some newer F-22's?
Their next show isn't till Oct 11 in Louisiana so got time to get back here and fix them :)
The Langley F-22 Raptor Demo Team also had a rough time at EAA Oshkosh back in July 2025. Same scenario. Luckily the F/A-18E/F Rhino Demo, and the F-35 Demos pitched-in to fill the gaps.
1245- Drago 51 flt (4 X T-38s) on Flyover discrete (279.575). Also, A2A on 238.825. At 1308 w/ZDC Lexington (281.4) on way back to Langley. Also, working 7th FTS Ops (357.1)
1305- Scan 06 (CRJ-7 N806X) off BWI heading east. On Northrop discrete w/Base (123.225).
P-6 got your DRAGO-51 flyover at about 18:40 mark..
mdmonitor
Posted on another list. Interesting.
Beginning at the 1300z window the E6Bs became very active and remained so to the end of the UTC day. Spectacular in hindsight.
There were 7 known flights of E6Bs active at the same time:
6 flights visible on ADSB mapping sites.
1 flight was apparently Due Regard/dark to the mapping sites (TACAMO LANT as has been the recent case with the LANT missions).
There were restoral rebroadcast missions for LANT, PAC and the Gulf.
There were VLF broadcasts over all 3 bodies of water.
Two of the E6Bs conducted numerous data exchange comms on USN CHARLIE Window frequencies.
Two E6Bs out of OFFUTT and return to OFFUTT.
Two E6Bs out of TINKER and returned to TINKER.
One E6B out of TRAVIS to TINKER.
One E6B out of TRAVIS to the Pacific [TACAMO PAC.]
One E6B dark; perhaps out of PAX [TACAMO LANT].
JetWash
Fairfax, VA
From a while ago, I remember someone posting about an “AR9” route that wasn’t listed anywhere. NOTAM posted today should clarify that:
10/019 ZWY AIRSPACE DUE TO A MILITARY STNR ALT RESERVATION, SEA POWER DEMONSTRATION, AR9 SHALL BE CLOSED FROM ORF TO ZIBUT INTERSECTION. THE FOLLOWING INTERNATIONAL ROUTE WILL BE IMPACTED : AR9 ALL FLIGHTS WITH ROUTES THAT WOULD NORMALLY TRANSIT THIS AREA SHALL USE THE FOLLOWING REROUTES: AR9 USE ORF J121 SIE B24 LYNUS AND REVERSE. SFC-UNL DLY 1500-2100 2510031500-2510042100
