Mip 5000 console channel marker tones
kd5vjn1307
Stillwater, Oklahoma
Checking to see if anyone knows if the mip 5000 console has the ability to add a channel marker tone as feature? Google has brought forth little to no information as to this extra features available to this console. Thanks in advance.
N1GTL
CT
I have some work to do on a system tomorrow. By Chanel Marker I assume you want the channel to beep every x seconds? I'll check for the option in the CSDM configuration .
firefive76
Kansas
I'm not sure how closely the MIP5000 and the MCC5500 are related, but on the MCC5500, the channel marker is all set up from the configuration on the actual MCC5500 program rather than through the CSDM. Really the only thing you can change in the CSDM for the channel marker is the delay time before the beep is sent.
N1GTL
CT
Exactly. Thank you.
There is a channel marker option. Open your console configuration screen (not CSDM).
Go to EDIT > ADMINISTRATOR MODE
Put in the password
Then go to RESOURCES > GLOBAL RESOURCES.
Under that there is a function tab. Scroll down to "MRK TONE"
Drag it to the right and put it under "OP WINDOW" or "TOOL BAR", wherever you want it displayed.
Click on the resource you want to put the marker tone on then hit the marker tone button.
By default it will beep every 10 seconds.
