Motorola NAS tips?
Omie09
I have an XTS5000, and I recently set up NAS. It doesn’t affiliate at all. However, I am having trouble hearing transmissions and the radio is missing them. I’m unsure what the issue is but I feel like I may have possibly messed up the band plan. Any tips to stop missing transmission? (Monitoring Starcom21)
MTS2000des
5B2_BEE00 Czar
I have been perfectly with talk groups in Will county. This issue is fail 001 while trying to monitor Starcom in Dupage county. As far as I know I have set up the trunking system and scan the same way and I was asking for a solution or answer.
The answer is your 20+ year old radio is dying. Fail 001 is a synthesizer out of lock. The XTS5000 BSM will tell you that.
See page 64:
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I am aware of that. Are you also trying to say that the fail 001 is due to phase 2 activity on the talkgroup?
From memory, my XTS completely ignores TDMA channel assignments. My guess is the bandplan is wrong, like maybe for 700 MHz. Does the site in question use 700 MHz?
Anderegg
Enter text in this field
San Diego
Here is a tip...slave a non user editable empty scan list for all trunking personalities...these radios are not able to TX or affiliate when they are busy bonking "EMPTY LIST" at you.
An extra extra extra step to lock down your rig. I have a legit subscriber APX that doesn't affiliate if I empty a scan list and change channels to a talkgroup with scan switch on.
Paul
Omie09
Paul
You are saying to put an accessible channel with trunking personality? A little uneasy about this, but thanks for the tip.
chrismol1
No, that user is not saying to make a trunking talkgroup accessible by button or switch, they said in their findings it's an "An extra extra extra step to lock down" in the chance of a screw up and selecting a real trunked talkgroup. It's an interesting find. To put an empty scan list on the trunking personalities, (remember NAS is using the conventional personality scan list, not the trunking scan list) so if a trunked talkgroup is somehow selected and programmed personality with that empty scan list, the radio is caught up in a error loop instead of attempting to affiliate
merlin
DN32su
My XTS, I usually hear dispatchers fine, some field users ar ground out with noise, eating the mic or too far from it. XTL with same codeplug sounds much better.
So how do you get digital voice if the scanlists are analog. I thought first 16 channels (analog) hide the digital RX only lists.
Anderegg
San Diego
Yes exactly...I tested this by removing my scan members, selecting scan, then changing channels with a scanner next to me set to the input of the control channel...no blinky red LED, no chirp of affiliation either...left it that way for like 5 minutes to see if the bonking would ever stop, but it doesn't time out.
Paul
Omie09
Okay
Okay, this makes sense. I have not heard of this before. Usually just use the switch to turn on TX Inhibit to “lock it down”.
K2NEC
5F6
Okay
It doesn't work like that. The radio will still try to affiliate with tx inhibit and it won't unmute the audio if it thinks it should be affiliating but can't
Omie09
Really? I heard that TX Inhibit will not allow any sort transmission as a feature for hazmat situations or something of the sort.
