Motorola to Kenwood - ARC4 Encryption Troubles
firemedic834
I'm looking for help and guidance on the following trouble with a P25 conventional frequency with ARC4 encryption not transmitting or receiving between Kenwood and Motorola radios.
  1. P25 Conventional Frequency
  2. ARC4 Encryption
  3. Motorola APX8000, Kenwood NX5200, and Kenwood NX5700 with the proper encryption modules installed.
  4. Frequencies match in the Motorola and Kenwood programming software.
  5. Key ID, key name, and key data all match.
  6. The frequency will encrypt between two Kenwood radios, however; not a Kenwood and Motorola.
Any suggestions or ideas?
Thank you.
rbrtklamp2
Dupage County, Illinois
Re-Check your TEK and KID in the 8000. ARC4/ADP is a universal crypto method and they should all work together. Use a keyloader or KFDTool if you can to ensure the data is correct in each radio. If you are using software encryption ensure your TEK and KID are correct in each unit.
Giddyuptd
Here and there
As Rbr said. I don't have any issues between these radios using ADP and arc 4. Is the firmware current for the kenwoods?
firemedic834
Kenwood doesn't allow for a key loader to be used for ADP/ARC4. Only AES and DES.
firemedic834
Problem resolved. Converted the key ID from HEX to decimal. Able to communicate now between Motorola and Kenwood.
