Multiple scanners/one antenna.
jjhendo
Eagan, MN, US&A
I have a SDS200 and a Pro 2052 I'd like to use with my DS-150S discone. Guess I need a coupler (or multicoupler?), the one on Scanner Master is still sold out, any other reccomendations? Is it as simple as that or any other parts or considerations? I may use this antenna for transmitting also, does that change everything? I'm a bit new at this..
Ubbe
Stockholm, Sweden
If all your signal strengths are good, check with the SDS200, and are stronger than 90dBm then you can use a passive splitter that isolates the two scanners from each other. A CATV splitter costs $5 and works fine with scanners.
If you transmit you should use a switch to disconnect your scanners and also ground their antenna input to prevent them to be damage from the high transmit signal levels. I believe there are such switches but will be a bit costly at $100.
/Ubbe
tvengr
Well Known Member
Baltimore County, MD
jjhendo
Eagan, MN, US&A
/Ubbe
Ok, sounds good, thanks. I have the top belcony here, kinda wondering if I could even ground anything. I'm afraid to ask the hoa. 😅
Ubbe
Stockholm, Sweden
A passive splitter attenuates 4dB so check if that are aceptable. A suitable switch for transmit are linked below and also get pigtails or adapters. If you try and get F connectors at each device, using adapters, you can use cheap ready made coax lengths with F connectors.
/Ubbe
Indianabrad
Jasper County, IN.
Just wanted to say, I don't know how they did it with the SDS200, but with just a simple whip outside, only 6 ft off the ground, out of the 5 sites I get, 2 of them are 30 plus miles from me, one is that far south and the other is that far north. The SDS200's "hearing" ability is uncanny.
Ubbe
Stockholm, Sweden
I've never seen any other scanner before receive 30+ miles on a near ground whip outside and look at how many scanners I have in my sig to compare it with.
And how many miles did you get using that same whip with your other scanners?
/Ubbe
jjhendo
Eagan, MN, US&A
/Ubbe
Looks to be for tv, buy would this work? I thought this type of connection were only for a/v..
Ubbe
Stockholm, Sweden
It's not made for transmit, the switches are probably too weak for it.
You absolutely need a switch that grounds the connection to a scanner to protect it from damage when you transmit with high signal levels.
/Ubbe
N1NCZ
Conway, SC
The Switch being referred to would be something like DIAMOND CX-210N Where onside would go to your splitter and the other to what you want to transfer with. Also if you can add a ground (without the HOA getting upset) it will help - especially when transmitting.
Good Luck Rich / N1NCZ
jjhendo
Eagan, MN, US&A
Ok, cool. I was looking at getting something like a Wouxun KG-Q10H quad band and I guess a discone would be handy to transmit with all those bands as well as recieve for the scanners, if I can. Thanks.
buddrousa
It is generally not recommended or code-compliant to ground an antenna directly to the outlet ground inside your home. The National Electrical Code (NEC) requires that antennas be grounded to the home's grounding electrode system (GES), typically the ground rod at the power meter or breaker box, not the internal outlet ground wire. While the outlet ground is connected to the home grounding system, it is not the proper path for antenna grounding because the outlet ground path inside the house is longer and may have multiple connections increasing resistance and noise, making it unsafe and ineffective for antenna lightning protection and static discharge grounding.
The proper and legal way is to run a direct grounding wire from the antenna mast and coaxial cable grounding block outside, as short and straight as possible, to the home grounding electrode system or grounding rod, following NEC section 810 and section 250 requirements. Using the home's main grounding electrode system minimizes lightning and static electricity risks effectively.
Summary:
  • Outlet ground inside the home is not a code-approved antenna ground.
  • Proper grounding is to the home's grounding electrode system, usually a ground rod or the power meter/breaker box grounding.
  • The grounding wire should be copper, minimized in length and bends.
  • Antenna and coax cable must both be grounded to this system.
This ensures safety, noise reduction, and compliance with electrical codes.
