Nebraska (Statewide) Wireless Interoperable Network "N-WIN"
ORION_NE
Onawa, IA
anybody have an idea on what talkgroup "3080" is?? dnt see it listed in the RR database. secondly, ive been hearing a lot of radio traffic re-direct when liscense/records checks happen. no more hearing your neighbors records checks on main talkgroups. bummer. thanks!!
What talk group were they switching from?
NSP has started using the encrypted dispatch talk groups as info channels. Troop A has been doing this for over a year. The rest of the troop areas are starting to do the same.
33kracing
grand island, ne
NSP has started using the encrypted dispatch talk groups as info channels. Troop A has been doing this for over a year. The rest of the troop areas are starting to do the same.[/QUO
they all switch from their respective talkgroups... i.e. trp c dispatch 1 & trp c dispatch 3...
cellphone
Silent key.
Ahwatukee, AZ (Phoenix)
Has anyone ID'd these encrypted talkgoup numbers yet? These should be easy to catch. When you hear "Switch to secure x" then an encrypted talkgroup becomes active with the same radio ID's, you've got it. It would be nice to have these documented in the DB even though we cannot monitor them.
cellphone
Silent key.
Any of these sites active yet? Last update I heard was March for them to be active, so they should be online soon if they are not already.
Here are licensed freqs for the 3 new sites. Can anyone confirm if they are active yet? If so, can anyone confirm site numbers and control channels?
Benkelman (Dundy County)
154.2350
154.6650
154.9200
154.4375
South Lincoln
155.0325
155.4225
155.6325
155.7225
York
154.4225
154.7775
155.5125
156.1425
realgeo
Murray, NE
And, don't forget the new Nashville, NE site!
Nashville - WQTN423
156.1425
155.8725
154.9500
154.6800
154.1225
Unfortunately, I haven't detected anything on these frequencies as of yet! Soon, perhaps!
Lincoln, NE
Just tried Lincoln south site. Getting full signal on the CC. Will report back for any traffic.
Sent from my SM-N900V using Tapatalk
ChopperDan
Have HQ traffic on Lincoln South tower this morning. 30 May 08:39 Local
Right now all of HQ Trp traffic seems to have move to South nothing at all on the North tower.
Lincoln, NE
001-082
realgeo
Murray, NE
Good evening, Joe and all!
Long-time since I've posted here, but was in Lincoln today and snagged a capture from Pro96Com, as follows. Unfortunately, I didn't have the RR info loaded into this copy of Pro96Com, so the names of the other sites don't show-up!
The tower # is 182 and check-out that voice channel - 152.780? Kinda' getting into the paging area of the VHF band!
Nothing yet on the Nashville site, and didn't have time to run out to York, but would have to think that one might be running too, now.
73
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 144
System Name :
WACN : BEE00
Tower Number (Decimal): 1-82
Tower Number (Hex) : T0152
Tower Description :
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Fri May 30 15:01:01 2014
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,150.57500,0.00250,-4.38250,"Confirmed",0.01250,1
05,149.00000,0.00250,0.00000,"Confirmed",0.01250,1
06,161.00000,0.01250,0.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"05-1512","v",152.78000,"04-2986",158.04000,1,4
"05-2413","a",155.03250,"04-3466",159.24000,1,0
"05-2569","a",155.42250,"04-3499",159.32250,1,0
"05-2653","a",155.63250,"04-3517",159.36750,1,0
"05-2689","c",155.72250,"04-3550",159.45000,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
155,"T0137",144,"05-2632",155.58000,""
168,"T0144",144,"05-2476",155.19000,""
169,"T0145",144,"05-2884",156.21000,""
170,"T0146",144,"06-0928",172.60000,""
176,"T014C",144,"06-1026",173.82500,""
177,"T014D",144,"05-2680",155.70000,""
179,"T014F",144,"06-1025",173.81250,""
ORION_NE
Onawa, IA
George,
One thing that really stood out when I read the tower info from your post was
Flavor-Phase 2!
I have an older version of pro96com cause my doesn't have a "flavor". So can I start the paranoia now and ask does this mean the system is phase 2/TDMA capable.
nd5y
Wichita Falls, TX
According to the bandplan (Tables) posted above the system is showing TDMA capability on the 700 and 800 MHz bands only. That would be the ones with 2 under Slots.
Some of the military VHF and UHF P25 systems down here are like that, the control channels broadcasts extra band plans for 700 and 800 MHz with 700 and 800 MHz showing TDMA.
realgeo
Murray, NE
Anyone close enough to the York tower to tell if it is online?
Howdy Joe and all!
Sitting in York, NE, I observe that the site, 0181, is, indeed, online per the following Pro96Com data:
FileVersion:8
-TowerInfo
System ID : 144
System Name :
WACN : BEE00
Tower Number (Decimal): 1-81
Tower Number (Hex) : T0151
Tower Description :
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sun Jun 8 13:58:30 2014
-Tables
07,158.00000,0.00250,0.00000,"Confirmed",0.01250,1
-Frequencies
"05-2311","ad",154.77750,"04-3484",159.28500,1,0
"05-2605","a",155.51250,"07-0535",159.33750,1,0
"05-2857","c",156.14250,"04-3556",159.46500,1,0
-Neighbors
158,"T013A",144,"05-2656",155.64000,""
159,"T013B",144,"05-2611",155.52750,""
172,"T0148",144,"05-2350",154.87500,""
173,"T0149",144,"05-2650",155.62500,""
73
