Need help identifying unknown talkgroups in Howard County
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
There is such a way -put it on the submission ticket and it will be added as notes in the entry...;
I've seen a plethoria of folks buying WS1040-1065s, Pro 106-197s and some go into sticker shock when they find out their system is going to go, or has gone to P2. Obviously this shows people who aren't doing their homework before buying...Mike
maus92
The OP
Right now, only FDMA waveforms are licensed, even though the system reports itself as Phase 2. The county would require more tower sites for a robust Phase 2 system. 8-12 mile spacing between sites seems optimal for P2.
maus92
The OP
TBH, if people want to hear pristine audio on a Phase 1 or Phase 2 system, they need to invest in the right equipment.
n1nlr
Looks like the HCPD has cut over to the new system.
Not sure if anyone else is left on the old Motorola system now. Most of the activity I see now is connected over from the p25 and occasional people with their radio in the wrong zone.
maus92
The OP
Yes, there are still users on the old SmartZone system, particularly one marked "Ellicott City Building Coordinators" (tg37008.) Some police units mark up using what looks like old radios judging by their UIDs.
ThePhotoGuy
Maryland
Some new talkgroups...
11050 - Detention Center Ops
11111 - Facilities Related?
11130
11135
11140
11142
11166 - School Transportation
11182
11187
ThePhotoGuy
Maryland
11182 - Call signs of "security" and "oc"
11187 - Tickets and Programs. Parks? Robinson Nature Center?
n1nlr
It looks like the old Motorola system has been shut down.
Sounds like they are moving the frequencies over to the P25 system now.
maus92
The OP
I'm seeing the following new freqs added to the P25 site around noon:
852.6375
852.8000
853.0375
853.0625
857.2375
n1nlr
852.6375
852.8000
853.0375
853.0625
857.2375
Those are what were left on the Motorola system which is now dead.
Think I heard them today going from site to site turning off the old Quantars.
baybum
Howard County
Does anyone happen to have a Pro-668 file for Howard County I can try? I set mine up with a new Vscanner dedicated to the new P25, it scans, but I get nothing when scanning. Nothing on the S-meter.
My Pro-96 is at least getting something, when it doesn't garble.
Thanks,
Mike
maus92
The OP
Thanks,
Mike
Good luck. P25P1 LSM will be difficult with older scanners.
baybum
Howard County
I understand, but I should be getting something on this 668. I get Phase 2 just fine. And I get Howard about 90% on my real old Pro-96. Again, just looking for a file I can try, then I'll report back on performance.
maus92
The OP
It's not really about Phase 1 or 2, it's more about where you are in relation to a transmit site - or multiple sites. With a non-optimised radio, you need to be really close to one tower site, and far away from any others. Easier to do with a wide area system like FIRST; harder to do with a more localized county system where the sites are closer together. Good luck - I know the Balto County people had a hard time when they went to a P1 LSM system.
baybum
Howard County
Yes, again, I understand all that. Just want to try a working file, then I'll report back. One scanner works and the other doesn't, in the same room. Want to rule out a configuration error. Let's give it a few days to see if someone with a file responds.
maus92
The OP
Glad you got it working - I did a test load of the new Howard system in my GRE800 nee WS1080, and was going to drive to Columbia today to test it, but now not required. The last time I loaded a P25 simulcast system in it was to test FIRST in Cecil County, and that did not go well - very poor results. It was mostly deaf, while the SDS was busy receiving everything.
baybum
Howard County
Yeah, it's a little choppy, but not bad enough to drop $700 for a new radio. That's based on my preference of only being interested in one county/system. (HoCo)
maus92
The OP
OP25 might be an option for you if you have an old computer - works extremely well, and is well suited to monitoring one system.
blee1099
Picked up E-82 on 10903 today., I'm thinking A3. Also heard some chatter on 11187. I think its Parks & Rec chatter channel. Two females were chatting about closing up.
