Need Help!! Orleans County, Ny
ChadHenning
Kent, New York, 14477
hey folks, I am having trouble with my Uniden Bearcat trunk tracker V BCD996P2 I am currently using ARC XT to program it. I added all the Orleans county p25 systems/groups/talksites or whatever. I also added the conventional dispatch channels. I cannot hear any p25 channels or anything, only conventional. Is there a setting I am missing or am I doing it wrong. Just need help, I would like to hear units responding and fire grounds radios. HELP!
k2hz
Rochester, NY
Set the radio to just the Orleans P25 site and either ID search or just select any one Talk Group. You should see some "bars" on the signal dispaly. If it is unstable, you are probably in an area where the radio can't handle the simulcast distortion. Try different locations but be aware that radio, like most scanners, work poorly on P25 simulcast.
Unless you are fortunate to be in a location with the predominant signal from just a single tower, reception will probably be unreliable at best.
The only scanners designed for simulcast are the Unication or the Uniden SDS series.
k2hz
Rochester, NY
If you are in Kent, you are halfway between the Kendall and the Waterport-Carlton Rd towers and probably also getting a significant signal level from the Albion tower. Definite worst case situation for simulcast distortion.
wtp
Port Charlotte FL
press the function button and then the scan button.
it should then turn to "ID SEARCH".
and you should hear everybody, then we can work on the rest.
eastpembroke29
Batavia New York
I just returned this scanner would not pick up genesee county control channel even with my outdoor antenna the sds100 or sds 200 are the only they really work good enough
wtp
Port Charlotte FL
Genesee county is simulcast and the SDS radios are built to handle it.
the 996 is not and the outside antenna would actually make it worse, as backward as it sounds.
eastpembroke29
Batavia New York
wondering because I was just looking at a picture of east Shelby truck on Facebook I see they have a Ef Johnson mobile in one of their truck that was recently taken.
ak716
'Merica
I also found a recent picture. It appears they have either an EFJ 53SL or a 5300 Mobile, which are theoretically capable of operating on their system, assuming it's an 800MHz radio with the necessary feature sets. Also was a Harris XG-25, which is also obviously capable.
A while back, like 2012, a friend of mine had a work radio which was a EFJ 51SL or similar, but that obviously is dated info. I found another recent photo of another Orleans County fire department with Harris XG-25M and XG-25, so somewhere in that mix is what they have?
