New PPS Version: 4.0 (V0.4.0.36) Released
Echo4Thirty
Spring,TX
Date: 9/15/2023
Bug/Issue Fixes:
1. Added support for profile programming on additional product models.
2. Resolved data write errors when Relay Control is set to Timeout.
3. Fixed the issue of incorrect data writing when the Knob is set to P25C mode with Squelch Option under Radio Compatible Mode.
4. Integrated a third-party certified USB RNDIS Driver.
5. Removed Windows administrator privileges requirement when opening the PPS software.
6. Resolved the issue of erroneous storage when setting a custom Alert Tone in the Pager ID configuration screen.
7. Resolved the issue where P25 Trunking System public resources could not be imported from older versions, causing errors for users who hadn't previously installed the older version.
belvdr
No longer interested in living
You were operating at an elevated privilege without knowing it.
This is a huge security risk.
No, that's not it; I never disabled UAC. I may be remembering how I launched it incorrectly since I didn't launch PPS that much, but I never disable UAC.
rcid1971
How's the link to Radio Reference DB working? v0.4.0 Beta 32, I couldn't ever get to log in to RRDB
mikewazowski
Staff member
Forums Manager
Oot and Aboot
So I'm still running on the last pre-4.0 PPS with the latest firmware on my G5. What advantage is there to moving to 4.0 if I'm only programming one pager?
jtwalker
Gettysburg, PA & Fenwick Island, DE
And I would think v0.3.0 has seen it’s last update so you would eventually need to move to v0.4.0.
To realize the benefit of the public resources, you will have to rebuild your programming from scratch.
Hit_Factor
Saint Joseph, MI
You can export sites and control channels and reimport into the resource. TGIDs take some sorting, but it wasn't too bad. I have about 1500 TGIDs and it took about an hour to break them up with the appropriate systems.
CanesFan95
Analog already is interoperable.
FL
Can the pager simply be read by 4.0+ without having to re-program from scratch?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
That's what I'm questioning. For a single pager, I don't see any benefit to rebuilding my programming just to use the public resource feature and unless some earth shattering feature comes out that I absolutely must have, I can probably stick with v3 PPS.
The advantage mostly comes when programming multiple systems, the V4.0 PPS allows you to save TGs (and other resources) by system, compared to the V3 PPS that saved all TGs as one group.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I saw that as well and I could see it saving some time programming new systems.
