dmonty83 said:I have tried to figure out why my scanner scans so slow. I have three zones setup with a total of 45 channels and it takes at least two seconds to scan through the channels. Is there something else I need to look at. I changed the System Hold times to off. Any suggestions?
David
On a trunked system, the number of channels programmed has no affect on scan speed. The scanner has to dwell on each active control channel long enough to receive a full "frame" of data so that it can determine which talk groups are active on the control channel and then compare those active talk groups with the information you've stored into channels to see if it should switch to the voice traffic. This takes about 1 to 1.5 seconds per control channel.
