Official Starrsoft WIN500 Software Thread
scan-pa
RRDB Admin
Lebanon, Pa.
Official Starrsoft WIN500 Software Thread.
This thread is to report & Discuss anything related to The WIN500 software.
Starrsoft WIN500 Software: http://starrsoft.com/ Version 1.07 is now Available **** updated on 11/27/2007
System Requirements
In order to run Win500, you'll need the following:
* A copy of the Win500 program
* A PSR-500 Scanner
* The blue GRE USB Scanner Programming cable that came with your PSR-500.
* A Windows (2000, XP, Vista) PC. Sorry - 95, 98, and Me are not supported.
DonS
Franktown, CO
kevins669 said:
But the light will not turn off with the client, either. Turns on, though.
I'm not able to reproduce that. With Win500 Server talking to my PSR-500, and the client app connected to the server, I can click the light button and it turns on/off with my clicks. If I turn it on then wait, after 5 seconds the light goes out. If I want to simulate a "press and hold" (to force the light on forever), I hold down a SHIFT key while clicking the light button. I have noticed that if I've used the SHIFT key previously, I have to use it again to turn the light off.[/quote]
I currently have the PSR-500 broadcasting 8 NOPD channels.
Use the following in Win500 Client:
www.krazy.net
Port : 8088
Currently has 20 open ports... Want to test out load and bandwith for a couple of days before Mardi Gras.
Let me know of any connection issues or problems so I can adjust.
Sounds fine here.
radionut44
Kernersville, NC
Stick0413 said:
Go in the Favorite List text file that is in the same folder as the Client. Just go down a line and seperate all the fields by a comma.
Thank you! I didn't have that file. I only had the client.exe that I downloaded when I got the latest Win500. I just now did the separate download on the remote client and got the file there.
All is good.
Ron
radionut44
Kernersville, NC
Logging search/sweep hits
Don: are you planning to modify the history logging to log frequencies "found" in search/sweep (when search is an object in a scan list or in immediate mode)? It would be nice to let the radio spend time searching or sweeping and come back and harvest the hits.
Ron
3mary2
Las Vegas, NV
Ok guys all the technical wording lost me along time ago. I see there is a verison 1.41 while I am still using the one from last year. Is there a help file for someone like me on downloading versions to Win500 program. I also don't understand alot of the program as it is the first program I have ever used. I do love it at this point, but feel I must be missing easier programing steps. I realize DonS is a very busy man and unable to reply to all e-mails so I no longer try that. Have not poted here before as I don't always understand what you TECHS are talking about and the fact I don't want to appear stupid. any help at this point greatly appreciated.
jat1129
Don, hate to do it this way but I have sent you two E-Mails Starsoft but have not received an answer. Have you received them? if not how can I get in touch with you. I have a problem and would like to see if you can help me.
You can E-Mail me at jat1129@aol.com.
jat1129
It has to do with my registration key, not with the program itself. I love the program and have no problems with it at this time.
BOBRR
Boston, MA
"Group" and "Private" Settings For Trunked Sys TYPE ?
Hello:
In setting up for a Trunked System, am a bit uncertain as to the "Group" setting
and the "Private" setting for the Type object for the Talkgroup, and how used.
I have a System with two Talkgroups (both as wildcards) for it, but i see that I have the same CC frequencies for each of the Groups. This is obviously wrong, I would think.
Are there, or should there be, different CC's for each ?
Could someone please explain for me the differences between Private and Group, and what frequencies should be in each, and how utilized ?
Much thanks,
Bob
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
BOBRR said:
Hello:
Much thanks,
Bob
Set one of the Wildcards to Privite and leave the other as Group. Insure both are in the same Scanlist for the selected TSYS. The CC's are the same for all ID's in the TSYS you setup Use all red and blue freqs for the selected site.
BOBRR
Boston, MA
Pasting From Excel Problem ?
Hello,
What am I doing wrong -
I have two columns in Excel.
Column A is formatted as text, and Column B has Frequencies.
I would like to transfer about 20 Rows of the above to the program.
So, in Excel, I select Columns A and B, and do a COPY of them.
Seems to grab them all just fine.
Here's the problem, though-
Whenever i try to PASTE them into the program, all I seem to be able to do no matter what I try is to get the Frequencies pasted in the Alpha Tag program column.
Could you please tell me the exact steps to follow to paste the Excel columns A and B into the program, please.
I start out with an "Insert New item at End," and then i assumed if I just do a Paste here, it would fill up the lines below as required. It fills up the lines, but puts the frequencies
(Excel Col B) into the Alpha Tags column. The text that it copied from Column A never shows anywhere.
What are the exact steps to follow, please ?
Thanks,
Bob
fmon
Eclipse, Virginia
Bob,
Highlight an copy only the text and frequencies from the columns. Do not highlight A and B columns or any description info of the data.
Don't
Code:
Blue Angles as of May 2003 during Patrick AFB Airshow.  1
142.00000	Grd Support
142.62500	Grd Support
143.60000	Grd Support
164.90000	Grd Support
Do
Code:
Note, the software will paste the columns correctly.
BOBRR
Boston, MA
From OP: Re Pasting Problem
Hi,
Thanks for the help.
That's exactly what I have been doing, as you suggest.
Sure is weird.
Is "Add a new item at end" as the first step correct ?
Then, what should I do, or highlight, prior to trying to Paste it ?
-the whole new line
-just the alpha tag box
-or,... ?
Thanks,
Bob
eorange
♦RF Enabled Member♦
Cleveland, OH
Are you formatting the frequencies so there are 6 digits to the right of the decimal point? This is a must, and tripped me up the first time.
123.450000
Are you pasting in the CONV tab?
I just highlight the whole row and it pastes right in.
DonS
Franktown, CO
Actually, the "digit" requirement for a frequency column is 4, 5, or 6 digits after the decimal point.
Frank's second example ("Do") pastes just fine into Win500's "CONV" tab.
williafa
glen gardner, new jersey
Middlesex and somerset counties, new jersey
I have a psr500 and would like to use win500 to download both of these county files, middlesex county and somerset county county files only.
I notice both look like mult systems nad am not sure how to set up my scanlists.
I would like middlesex in one and somerset in another. right now i only want the county freq. not the townships. Do I need to make changes in win500 when I download to program or will it upload to scanner as is with no problems. I am new to this scanner as I had a PRO97 befor and programed it manually with some grief.
Any help would be appreiced as I do not have the time to figure manual entries.
Thanks in advance
Frank
