Ottawa Airport
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
453.0875BMAir CanadaAir CanadaFMBusiness
461.6375VCZ54RMAir CanadaAir CanadaFMBusiness
462.425CYA5RMAir CanadaAir CanadaFMBusiness
469.350VOT977BMAir CanadaAir CanadaFMBusiness
460.2125XLJ706RM110.9 PLAirport OpsAirport OperationsFMBusiness
460.3375VAJ538RMUS AirwaysUS AirwaysFMBusiness
Is this considered trunked for Air Canada ?
Cap + is DMR mode so you should be ok using the DMR mode to listen to it. Following the trunked may be a bit harder as I do not know if the BCD325 P2 follows Cap+.
From @gary123
I did look at my user manual and my BCD 325P2 can follow Cap+ system but I did find this Air Canada freq. I’m just wondering if that a trunk system?
So I am doing some experiments. I found a CAP Plus site that has a lot of freq's. It has range of 26.6 I have it locked on a control channel. I am going to see if that will pick up the airport system. I know it a long shot but want to try it out.
So I just programmed that other CAP site for DMR. I programmed the airport TG 71 which is operations, and I see CAP symbol and 1 signal bar and the control channel below.
The Air Canada frequencies are not CAP+. Possible explanation is in DSD+ Event window if
you were monitoring a CAP+ system then switch frequencies to conventional, the CAP+ may
still be displayed at the bottom, check that. If in doubt, clear the system line, may need to
exit/restart DSD+.
If you are seeing Airport TGs 11, 21....etc on the Air Canada frequencies that is interesting but
also worth checking, using RID's. Airport radios might be able to operate on Air Canada frequencies
but does not mean they are the same system.
As mentioned earlier, TG numbers can be the same in different systems but be unrelated. In my
logs I find several TG 1000's etc. on different systems.
I found this old Post from Dave regarding Air Canada. I'm not really sure what he means, but I'm still looking for more info about Air Canada.
I went to the CYOW plane watching lot with my DSD+ full version and knowledge of how to use it last week.
I can confirm that:
Airport Authority System:
Neighbor is Site 1
461.4125 is Cap+ Site 2 DCC=2 This told me it is First Cap+ Repeater (Ch1 and Ch2)
463.0125 is Cap+ Site 2 DCC=2 This told me it is Second Cap+ Repeater (Ch3 and Ch4)
TG=51
This site on this system looks submit-able.
Neighbor is Site 2 - looks like it needs another frequency as it is one of the repeaters.
460.2125 is Cap+ Site 1 DCC=1
TG 51
Air Canada
Site 1
460.7000 is DMR BS DCC=8 - I need more details to confirm the rest of the frequencies for the system.
I will be going back this week or next to confirm the rest of this. I will also attach my raw data for those interested in looking at it in an up coming post.
I found this old post
So I am at the airport doing so analysis of the frequencies listed. I have been seeing and hearing activity on two of the four as follows.
461.4125 CC=2 slot 1 and 2 CAP
463.0125 CC=2 slot 1 and 2 CAP
I did a system analysis of all four programmed in using the mobile only and it says 1 frequency only.
This will give me enough to program several versions of the system to monitor on my next visit.
I'm only hearing digital on 460.7 that is licensed to Air Canada.
Frank
An FYI the Alert road parking lot is not plowed.
I will try and find more info, but I would like to know how to do this. I have been also picking up chatter on the Cap +.
I have programmed the freq. of the site
I heard some comm's from this system. I will listen tomorrow to see what the ID's are.
Site Frequency Table​
LCNLSNFrequencyColor Code
011854.88755
012854.88755
023855.13755
024855.13755
035855.38755
036855.38755
047855.76255
048855.76255
059856.26255
0510856.26255
0611856.51255
0612856.51255
0713856.76255
0714856.76255
I just saw TG 201 on the Cap+ system.
It’s French. I don’t know if it's Air Canada or not, and I’m not really sure how to program the Air Canada system to be honest. That's what I would like help with now, to program the Air Canada system :)
I know the Air Canada TG are 1002 etc., but I don’t know what system I need or what site.
So I just programmed the Air Canada DMR conventional system now. I'm just waiting for comm's too, but I think i would hear something in the morning, as I did it at night time instead of the day.
I just would like to share this info just so i have everything i need to know
Frequency
LocationLicenseeDetails
TX118.80000OTTAWA AIRPORT (TANM)NAV CANADA – ONTARIO0001273985
RX118.80000OTTAWA AIRPORT (TANM)NAV CANADA – ONTARIO0001273986
TX121.90000OTTAWA AIRPORT ONTAIR CANADA0001115473
TX121.90000OTTAWA AIRPORT (TANM)NAV CANADA – ONTARIO0001273989
RX121.90000OTTAWA AIRPORT (TANM)NAV CANADA – ONTARIO0001273990
TX135.85000OTTAWA AIRPORT (TANM)NAV CANADA – ONTARIO0001273987
RX135.85000OTTAWA AIRPORT (TANM)NAV CANADA – ONTARIO0001273988
TX422.55000MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001757816
RX422.55000MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001757819
TX423.63750MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001708454
RX423.63750MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001708460
TX427.55000MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001757818
RX427.55000MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001757817
TX428.63750MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001708458
RX428.63750MacDonald-Cartier International Airport, Ottawa, ONBEARCOM Canada Corp.0001708456
RX460.21250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171254
RX460.21250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171967
RX461.41250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171255
RX461.41250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171968
TX461.56250OTTAWA INTERNATIONAL AIRPORTOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002204070
RX461.56250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002265458
RX461.56250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002265470
TX463.01250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171253
RX463.01250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171969
TX465.21250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171251
TX465.21250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171964
TX466.41250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171252
TX466.41250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171965
RX466.56250OTTAWA INTERNATIONAL AIRPORTOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002204071
TX466.56250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002265457
TX466.56250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002265469
RX468.01250Ottawa International AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171256
TX468.01250Ottawa AirportOTTAWA MACDONALD-CARTIER NATIONAL AIRPORT AUTHORITY0002171966
Just want to give info on what one of the freq says it’s digital DMR conventional I believe. I am downtown now, so I’m thinking I’m out of range but when I get back to my area I will keep listening.
RxRX
Frequency [MHz]427.55000
Frequency Record Identifier0001757817
Regulatory Service1
Communication TypeD
Conformity to Frequency PlanA
Frequency Allocation NameLM_CAN_UHF_DUPLEX3_12K5
ChannelB1316'
Legacy System Internationl Co-ordination Number
Analog/DigitalD
Occupied Bandwith [kHz]7.6
Designation of Emission7K60F7DWT
Modulation TypeLMR-DIGITAL
Filtration Installed3
Tx Effective Radiated Power [dBW]-
Tx Transmitter Power [W]-
Total Losses [dB]4.9
Analog Capacity [Channels]1.
Digital Capacity [Mbit/s].064
Rx Unfaded Received Signal Level [dBW]
Rx Threshold Signal Level for BER 10e-3 [dBW]-145
ManufacturerComprod
Model Number776-70HDWTM
Gain [dBi]7.1484
Antenna Pattern
Half-Power (3 dB) Beamwidth [Deg]
Front-to-Back Ratio [dB]
PolarizationB
Heigh Above Ground Level [m]15
Azimuth Of Main Lobe [Deg]0
Vertical Elevation Angle [Deg]
Station LocationMacDonald-Cartier International Airport, Ottawa, ON
Licensee Station ReferenceRepeaters
Call SignCFZ494
Station Type8
ITU Class of StationFX
Staion Cost Category
Number Of Identical Stations
Reference IdentifierOttawa Airport PushPlus
ProvinceON
Latitude45.32342778
Longitude-75.66730833
Ground Elevation Above Mean Sea Level [m]112
Antenna Structure Height Above Ground Level [m]13
Congestion ZoneM
Radius Of Operation [km]0
Satellite Name
Authorization Number010785955-002
Service3
Subservice300
Licence TypeS
Authorization StatusG
In-Service Date2019-06-12
Account Number049090000199
Licensee NameBEARCOM Canada Corp.
Licensee Address79 Wellington Street,London,ON,N6B 2K4
Operational Status-
Station Classification-
Horizontal Power [W]-
Vertical Power [W]-
Standby Transmitter Information
gary123
Nice work on using the TAFL database.
The 2 52x Bearcom frequencies are site 17 on the PushPlus system (Sys ID:201). They are in the ARC-XT PushPlus 201 file. I have not identified the system/site for the 46xMHz frequencies yet. The license says they are DMR TIII. They may be a stand alone system.
@gary123 I just programmed all of the freq. I know I did it too late while it's dark, but tomorrow I will keep listening and take note of the colour codes to see which person is talking. I put them all in digital search as I don't know the colour codes.
gary123
Yes that is how to locate the colour codes. Usually all the channels on a particular trunked site have the same color code. This may be useful in pairing discovered frequencies.
So, I just did a Custom Search for DMR conventional I haven’t came across any chatter ye, but what I am thinking is it best it program all of the Bearcom freq as DMR conventional,
The only thing I don’t know is I don’t know what colour code the for airport sites that Bearcom owns, so I am lost what to do with that.
Oddly enough, I just tried another Custom Search and I heard the word hanger like, airport hanger. The guy said you probably left it back at the hanger.
gary123
Try and ID's the TG and user they can then be added to the DB.
Try and IDs the TG and user they can then be added to the DB.
I will do up a log of what I find and post it :).
The system I had in the unit was the following based on what I thought was the same system. Looks like we are looking at two separate systems at the airport.
CYOW Air Canada
Site 01 Parkade Roof
DMR One Frequency
460.700000 CC=8
Now both are ready to go and I will be in and around CYOW this morning.
I see 422.5625 CON with bars. I have it on hold from Custom Search. No voice yet, but there are bars.
No airport coms yet on that TG I heard. It wasn’t part of airport sound like a dumping site for unloading. I will see what tomorrow brings.
mmisk
Ottawa Canada
The two talk groups below are all that seem to be on 201-17 so nothing interesting to listen to there.
; 201-17 Airport NL: 1 4 6 11 12 weak signal
Con+, 201, 17, 1, 422.5500, 0.0, 0
Con+, 201, 17, 3, 423.6375, 0.0, 0
Con+, 201, 312188, 50, Normal, 183, 2025/10/05 19:08, "CYOW FUEL"
Con+, 201, 313703, 50, Normal, 435, 2025/10/05 19:09, "CYOW Shuttle"
CYOW Air Canada
DMR One Frequency
460.700000 CC=8
►422.5625 is repeater 2, slot 3 and 4 for site 201-12.
I can confirm that:
Neighbor is Site 1
TG=51
TG 51
Air Canada
Site 1
Frank
011854.88755
012854.88755
023855.13755
024855.13755
035855.38755
036855.38755
047855.76255
048855.76255
059856.26255
0510856.26255
0611856.51255
0612856.51255
0713856.76255
0714856.76255
I have very little time but here is some info:
460.2125 is repeater 1, slot 1 and slot 2 Cap+ system
461.4125 is repeater 2, slot 3 and slot 4 Cap+
463.0125 is repeater 3, slot 5 and slot 6 Cap+
It is apparently at YOW per: Ottawa International Airport Authority Trunking System, Ottawa, Ontario
I have it programmed into DSDplus as follows:
Cap+, 6015, 2, 1, 460.2125, 0.0, 0
Cap+, 6015, 2, 3, 461.4125, 0.0, 0
Cap+, 6015, 2, 5, 463.0125, 0.0, 0
I heard these today @gary123. I'm still working on finding the airport personnel.
312188TCYOW AFSCanadian Fuel ConsortiaBusiness
313703TCYOW ShuttleShuttleTransportation
Are you able to provide me with the freq for the airport personnel ? :)
I’m sorry but what's that mean? :) Is that for the airport personnel or for one of airlines personnel ?
Ok thank you now with that info will I able able to reach it ? As it is a repeater? That's what I would like to know :)
gary123
I take it the 460.2125, 461.4125, and 463.0125 are a stand alone CAP+ system.
I take it the 4602125,461.4125 and 463.0125 are a stand alone cap+ system.
I just put in those freq's and got no signal, but as I did before I’m gonna try and program another CAP system and see I think maybe CAP system can be connected to one another??
It is very weak where I am.
I have no way of knowing if you can receive it at your location.
Why don't you program all the systems listed and see what you can receive?
Here is where the list is:
Ottawa County, Ontario (ON) Scanner Frequencies and Radio Frequency Reference
Have fun.
I will do that and report back ! :)
