- Joined
- Jun 29, 2023
- Messages
- 32
I just received a BCD436HP. I made that decision following these 2-posts: Pre-Purchase Help for Northern Johnson County (Bargersville Locale)
BCD325P2 or BCD436HP as my 2nd. Scanner Purchase in 45 years?
I've been struggling with programming, specifically what Favorites to specify. I've scrutinized the RR Database for Marion and Johnson Counties and am trying to associate what I see there, with what I find on Sentinel's output.
First, living in Bargersville, I wonder if I will be able to pick-up Indy PD and FD channels? If absolutely not, there is obviously no need to program them. Also, closer to home, I would like to know what Johnson County/Greenwood/Whiteland/Franklin and any other areas you would recommend?
Basically, using Sentinel for Indiana, I looked: <Statewide>/<Indiana Project SAFE-T> for Indy (Marion County), and then further down to <County>. But I'm at a loss what specifically to select. Thus, once I’m in the correct section, what do I pick for fire and police, to put in my favorites? And/or for public safety channels, what would you recommend?
Compared to Sentinel's aggregation of RR data, I tried Butel AR536Pro and selected: Statewide/Truck Systems/Ind. Project Hoosier SAFE-T/….and received:
Like anything else, once it’s known, it’s easy. But, based on my location, I would sure like to know what specific Favorite(s) input you would begin with.
Also, please be mindful that I’m at the bottom of a learning curve when it comes to scanners and what to scan. So much so, that I had trouble inserting the time. I wondered, what the heck are these plus and minus numbers? Yeah, GMT offsets!! Another instance of it's easy once you know!!! So, it would be a big help for someone to provide specific recommendations relative to my location. Like output in the form of Sentinel or Butel output, that I could find in either program; which I could then insert into a Favorite list or two, that would get me up an running with something interesting. Because without knowing accurate input, I wouldn't know if I had ears or not, on the longer distance signals like Indy et al....Thanks!
PS. BTW, I tried the Zip code programming method and then setting the scanner to limit range to 20-mi. and turned-off most nationwide systems & service types. The scanner was scanning, but I didn't have a clue what I was receiving, because I didn't insert it. Also, I didn't know if the appropriate PD and FD channels were inputted and if they were, whether they were too distant to receive.
- Sites: 156
- Talkgroups: 2227
