Potential dumb question about mounting my Stryker AR10 magnetic mount CB antenna
merlin
DN32su
The black plastic keeps the mount from scratching paint, leave it in place.
Should be a large metal washer stuck to it, that is for shipping (storage) remove that.
Don't need metal to metal, the capacitive coupling at RF frequencies sees that short.
niceguy71
Massachusetts
you sound like you know this first hand? do you own a Stryker? I never see anyone on RadioReference speak of the Stryker, even though I hear great things about it.
HartB
Wayne county GA
The underside of that black plastic is foil and is required to help that capacitive coupling for “grounding”. Do not remove it unless you want marred paint and swr/ground issues. I know this because I helped the head puppet at Stryker redesign the internals of the coil after they had major issues with water leaking into the coil and causing shorts resulting in radio damage. They tried to copy a Wilson 5000 but had the tap for the coil shunt messed up. The current version coil can be opened allowing adjustment of the ground shunt on the coil. Unless you have the equipment to do so I don’t recommend adjusting this. It is set for optimal 11m performance as is. This little feature and the plastic foil liner covering the magnet were nice improvements. Then he added the blue light gizmo after the fact because the more chrome and lights it has the better it is for cb sales.
ind224
Indianapolis
A Wilson 5000 has a separate foil and protector and a repair kit that comes with the foil and protector. Plus, unlike a K40 it is easily field serviceable with bolted assembly not a rivet. I have used the repair kit foil and protector for my many over the years RS 20-032 scanner antennas as well.
