I'm fairly new to the whole trunking tech. I have a PRO 163 and would like to program in the local county TRS. I have programmed in the control channels and receiving transmissions.
FW Version 1.08
Sheboygan County Trunking System, Sheboygan, Wisconsin - Scanner Frequencies
The system is "rebanded" and after reading around on here I am under the impression that I need to use software and programming cable to enter the multi-table.
However I found a option which is not documented in the manual and think it is for programming the multi table without the scanner.
The secret menu can be found by PGM - TRUNK - FNC - 2
It asks for 3 sets of { Base, Offset, Step }
If this what I need to program in the rebanded system, what values do I need for those settings?
FW Version 1.08
