;pro 2096
longfeather1
Chester IL 62233
I can not program my pro 2096 police scanner i got a new usb for it and when i try to program it say all channels locked ?
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Sounds like there's nothing programmed in the scanner... Check out this thread--it should help you sort program the scanner:
Good luck!
gmclam
Fair Oaks, CA
They are all locked because you are in SCAN mode with nothing selected. If you've programmed something, press the number keys to toggle on and off banks/lists. If you haven't programmed anything, you could use WX to hear NOAA weather, TUNE and enter a frequency or SEARCH. To see if something is programmed press MAN and cycle through the entries.
