jason74koch
- Joined
- May 12, 2013
- Messages
- 9
I am working on a radio shack p197. I’m trying to figure out how to program p25 channels. I know what the DEC is. But having trouble converting it to a frequency. Thanks
Apparently not.I know what the DEC is.
hex codes do not convert or relate to frequency.
I’m in Nebraska, North platte area. Trying to scan the State Patrol. I’m currently not using any software to program it. Recommend any software to use? ThanksIn a P25 trunked system, the frequencies go into a site or sites. The numbers in the DEC column are talkgroup ID's, also known as TGID's. They are not frequencies. In a conventional system, each channel has its own frequency. In a trunked system, all of the frequencies are shared by all of the users. A talkgroup in a trunked system is the equivalent of a frequency or channel in a conventional system. What is your location (city, county, state) and what programming software are you using?
I’m trying to monitor the state patrol. It’s a p25. I’m Hour south of north platte. ThanksThe trunked system must be assigned to a scan list. When you toggle the scan list, you will turn the trunked system on and off. What trunked system are you trying to monitor? How far are you from Sutherland? There are sites at both North Platte and Sutherland in Lincoln Co.
