RadioFeed
tulsascan
Tulsa
Proscan #1
Proscan is the best scanner software out there. the number of scanners it supports, thank you for not making us pay every time a radio is supported and for all the great feature that Proscan offers. hands down the best. Did I say the best supported software. Rock on Proscan
pearock1
Radiofeed
I am setting up a private feed and for some reason i cannot connect to my RadioFeed on my iphone using my 5-0 or other scanner programs. Scannercast works just find but it seems like i can only connect to RadiFeed with a browser. Any suggestions?
ProScan
Software Provider
Ontario, Calif.
Are you using an IceCast or Shoutcast server? If yes then you want to use the Source Client feature. The browser works with the Web Server feature.
pearock1
No was under the impression if i were going to set up a private server that i was to use the Web Server. The reason i want it to be private is so i can have access to all the channels as not to violate the TOS on Broadcastify.
ProScan
Software Provider
Ontario, Calif.
Yes use the Web Server. Browsers and media players can connect to it. If the browser can connect then the media player can too.
pearock1
I have tried 5-0 radio and Police scanner+ and both will not connect to RadioFeed. Both of those apps work fine when i broadcast using Scannercast. Like i said my web browsers on my other PCs work fine. I really would like to use RadioFeed so i can password protect my stream I don't see where Scannercast can do that.
ProScan
Software Provider
Ontario, Calif.
Are you clicking on the .m3u link? For that the .m3u files need to be associated with the media player.
If you are entering in the URL manually, don't forget the port number.
For troubleshooting leave it un-password protected until you can connect.
pearock1
Yes i have left it unprotected and i have entered all the same numbers in both players. Like i said when i run scannercast both players work fine when i us the local,external and the dns i registered for my ip.. I tried with and without the http:// in front of the ip's with and with out ports. It just seems like something about the RadioFeed. Maybe i'm doing something wrong, i don't know.
ProScan
Software Provider
Ontario, Calif.
I haven't heard of any reports of the Web Server not working. I test it again a little later.
pearock1
Is it important for the section that says "Stream name" part of URL to be fill out correctly. I wasn't sure what to put there.
pearock1
I put those values in but with my local ip and ports but still nothing coming through on the iphone app.
ProScan
Software Provider
Ontario, Calif.
I tested iPhone Chrome & Safari browsers and clicked on the "Listen Live" link and it works.
I don't see how in the 5-0 Radio Police Scanner to enter in a URL manually so couldn't test it
mule1075
Washington Pennsylvania
On my phone when I enter my info I have to drop the m3u of the end of the link.If that makes any sense.
Sent from my Z750C using Tapatalk
pearock1
In 5- Radio you just click on "Add your own fee" and type in the ip address with the port number.
