Rensselaer co P25 system
n2wjr
castleton,n.y.
rensselaer county p25 system
i found out from a few fire chiefs from the county i know that the new dispatch frequency 155.655 will be swiched from 46.10 some time in september of this year,how ever they haven't been given a date yet.and when they go to the p25 system they will be on portables/hts at first untill the mobiles are put in the trucks.
happy scanning
Com-Tech51H8
bureaucratic absence of presence.
BEE00
happy scanning
Yeah testing is supposed to take place now through mid September. Paging should be online when the sheriffs finally switch over to the 800 system and there 2ndary channel
Sent from my SM-G955U using Tapatalk
n2wjr
castleton,n.y.
oh ok i just know the 2 chiefs i talked to have not been given a date yet
Com-Tech51H8
BEE00
Yeah and most of the mobiles have been programmed as well as portable I know a few agencies were testing on the new system but I haven't had the time to actively engage in monitoring
sdunigan518
Troy, NY
Almost constant testing going on this evening. Sounds like testing signal strength by grid locations between dispatcher and techs. Logging what I can in Pro96Com
D
DaveNF2G
Guest
It looks like TG 1001 is going to be Wells' "radio repair" group on the system.
Com-Tech51H8
BEE00
ive set my logger up to catch all rensselaer co p25 traffic this should be interesting
Com-Tech51H8
BEE00
The Following have been logged:
TalkGroups:
1000
101
Uids: 1021-Wells
1036 -Wells
1038-Wells
9-Dispatch Console
10- Dispatch Console
sdunigan518
Troy, NY
TalkGroups:
1000
101
Uids: 1021-Wells
1036 -Wells
1038-Wells
9-Dispatch Console
This is very similar to what I've seen so far. Some hits on other TGs but haven't heard any actual audio on anything but those 2 channels and I believe from those 4 RIDs.
Com-Tech51H8
BEE00
what other tg have you seen active?
also there doing area specific testing by grid locations / tower locations from what im gathering. I have a ton of UIDS but only active on 1000 and 101
D
DaveNF2G
Guest
I have captured a lot of affiliations to other talkgroups, but no traffic on any of them. I suspect it happens when somebody spins the dial (or whatever mechanism steps through the talkgroups) on a radio.
Com-Tech51H8
BEE00
Dave I'm gonna dm you something that may correlate with what you've been seeing.
sdunigan518
Troy, NY
Logged TGs
I've logged TG 101-110,112,113,116,126,149,152,153,1000,1002,1003,and 1009
I've only been running Pro96Com intermittently though.
  • TG Log.pdf
Thunderknight
Bletchley Park
I see the RRDB has been updated...with what is probably the whole system! To whomever submitted it...thank you. But it does take the fun out of it too :)
D
DaveNF2G
Guest
I was going to say something about taking the fun out of it, but Thunderknight beat me to it. LOL.
sav1350
Capital District, NY
I'm going to venture a guess, and I could be wrong, that the entire system update is not accurate. That appears to have come from the last two pages of this document (https://docs.google.com/viewer?a=v&...29tbXVuaWNhdGlvbnN8Z3g6NmY5NzRhNjdmYTIyYTdiOA). It appears to be just a listing of every county radio resource. Some of the direct ground channels (analog simplex) channels are listed in there as well as 8CALL and 8TAC channels. The talk group numbers also don't appear to line up with what others have reported for testing. I don't think they are doing grid testing on the Saratoga County Fire Interop talk group.
Again, I could be wrong here but I would take that info with a grain of salt. I'm sure it's an accurate list of every channel option that will be available to be programmed into a radio, but not an accurate listing of TG numbers. I think the document is oversimplifying the term talk group.
