Configure each range correctly and then highlight each that you want to be seached during the session before clicking 'scan'.Ok that is a way, thanks did not try that possible. Use scan range rounded 440.00000 to 450.00000 because there is also new DMR network below and above PMR that use the 12.5 / 10 kHz step, in fact 2 new network so thinking, pick all users in one scan range for logging in manager
If only there was a really good pdf about using the plugin........
