SDR# SDR# Plug-in: Frequency Scanner updated
thewraith2008
Hi there,
In your GIF above, I notice the "8.33 kHz selector is not ticked.
Does it mean it's no longer necessary now that SDR# provides a 8.3333 step ?
Not sure what you mean.
SDR# always had 8.33 KHz step size available. It just doesn't correctly tune to the 8.33 KHz aviation band plan.
That's what the 8.33KHz selector feature is for. (for manually tuning the correct frequencies)
It's not ticked because I/they don't use 8.33 KHz band plan in my region.
morfis
Can you turn ON option in Configure > Channel Analyser > "Show debug info" and try again.
I will need to look into this further later if this fixes that issue.
With 'Show debug info' checked:
the display shows the number of hits, session file contains frequencies with number of hits and csv is created
ie. the plugin works correctly if that is set.
Unchecking it again and re-running the scanner (without actually shutting sdrsharp down) and again the logging doesn't work
thewraith2008
This is a update v2.2.2.0 to the great Frequency Scanner plug-in for SDR#.
This plug-in version adds/changes and fixes some items:
Code:
2.2.2.0 - Released
Added: Ability to offset 8.33 KHz 'channel name' on the main spectrum
- Maybe of use if you use 'Band Plan' position on 'Top'
  NOTE: Other plug-ins may display information on the frequency spectrum where this 8.33 channel label is displayed.
        This may help position label in a free area. (or not)
Fixed: Session hits was not functioning as expected
- The option 'Show debug info' was required to be enable for session hits to work. (This was not right)
  A conditional was placed to early in code. Oops.
Updated: PDF Documentation
- Please read it
see changelog.txt for more details
Documentation has been created to help with it's installation and usage, please read it.
NOTE: Support is not guaranteed. Especially if the answers are contained in the documentation or on this forum.
I have tried to be as thorough as possible with the documentation to explain usage and features.
I believe any questions can be answered by reading this documentation.
This documentation most likely is not complete and may contain errors and is not laid out as good as it could be.
Testing has mainly been done with SDR# 1784.
Very limited testing has been done with SDR# 1766.
Limited testing has been done with SDR# 1700.
NOTE: SDR# has been going through some changes (1732+) and it's new features may see this plug-in play up.
Download
NOTE: Use 7zip or WinRAR to extract files from the .7z file and read the .PDF file for installation and usage of files with SDR#.
HASH: a158f433c97829f790e821ed7b1f0250
morfis
sdrsharp1784/fs2.2.2.0
Confirm logging is functioning correctly again - thanks for fixing it
Also confirm the channel name offset works as intended with customised bandplan displayed at the top.
thewraith2008
Thanks for sticking with me to fix it. (y)
Latest version (v2.2.2.0) can be found here: MEGA - Download
Release post here
PA1NS
thewraith
Hello, I am new here.
I found a small problem in de Freq-scanner.
During scan the squelch is aut. active, but if you Stop the scan the squelch is (if On selected in Radio) OFF.
The Start scan and Stop scan the Squelch is ON - so Off - On - Off - On - Off ect.
I hope you can reproduce this , and fix it . Hi
Nico de PA1NS
thewraith2008
Yet another quick update
This is a update v2.2.2.1 to the great Frequency Scanner plug-in for SDR#.
Code:
2.2.2.1 - Minor Released
Fixed: Squelch state restoration order was wrong
Download
HASH: 11a96bb92e5a260f8523a0fc5fe270f4
PA1NS
thewraith
Thanks for fixing it. And thanks for all the time you have spend on this plugin.
I love this plugin !!!
Nico de PA1NS
Hi there !
Could somebody explain what's wrong here : I'm tuned to a station on 126.175, which reception is fine (SDR# shows 41dB SNR). But when looking at the "channel analyser" this signal is totally absent, as if it wasn't there. It is stored in the memory bank and not locked (green marker) ...
It tried different setting (step 8333, 12500, 25000, scanning 126000 > 126 5000 only), no way to "see" this one as "active' on the channel analyser window. Thus, the scanner does not stop on it despite it's quite loud. There must be something obvious I'm missing ...
Below is a capture that will probably explain better than my approximate sentances !
Thanks for you help and congrats again on this great piece of plugin.
thewraith2008
Hi there !
Your label for that frequency has "ATIS"
ATIS is a constant carrier transmission and the scanner when using 'Dynamic Noise Floor' will it null out.
This is used for removing 'birdies' or other constant noise that an SDR will see.
If you wish to 'see' it you will need to use 'Static Noise Floor'.
Latest version (v2.2.2.1) can be found here: MEGA - Download
Release post here
Release post here
That's a clear and fast explanation. Thank you so much.
rickderby
Hi great plugin, would it be possible to have the ability to set a file name for the csv logging other than the date, so we have the choice to have it split by day as the default or a continuous/ longer running single file please
TDR-94
Within the file they are sorted lowest to highest based on frequency. For display purposes you can have them low to high or high to low based on Label or frequency.
WFM is for broadcast FM. Everything else is NFM (most receivers tend to label it as FM but it's the same thing) and you can adjust your bandwidth and step size to suit
Can WFM be used for FM if the bandwidth and step size is adjusted accordingly? I need to keep NFM set to it's bandwidth and step size settings for other frequencies.
morfis
It might help if you explained what it is you are trying to do and how this relates to the frequency scanner plugin.
thewraith2008
This is a update v2.2.3.0 to the great Frequency Scanner plug-in for SDR#.
Code:
2.2.3.0
Fixed: 'Window 8' theme caused a crash on SDR# start-up when plug-in side panel visible.
Added: Option to disable auto scrollbar hiding.
Added: Context menu (right click) to new frequency activity list
- 'Clear activity time', 'Delete'
Download
HASH: bd51733e9300d9fe6de207e913ba61a9
hamradionl
RED UP / DOWN when do One mouse click the steps sometime go 2 or 3 UP
YELLOW UP / DOWN the same
no, i not hold mouse to long, just one very fast mouse click, mostly its the first click.......
morfis
sdrsharp 1784/scanner 2.2.3.0
Above problem not seen here - trigger and hysteresis buttons working as before with consistent 'single' steps up/down
