Set Up a VPN for Uniden Siren On Linux In 20 Easy Steps
How happy are you with your BCD536HP?
  • Prospective Owner
    Votes: 1 7.1%
  • YES
    Votes: 10 71.4%
  • NO
    Votes: 2 14.3%
  • Eleavated Blood Pressure
    Votes: 2 14.3%
  • Total voters
    14
  • Poll closed .
nosoup4u
High Bridge, NJ
I have setup OpenVPN on linux and while it isn't all that hard, unless you have linux/unix experience, it is not a very easy process to follow.
I would suggest replacing your router with an ASUS brand and install asuswrt. OpenVPN is built into the firmware and you can have it up and running in a very short time.
I
ilken
Guest
But does it stream audio over the VPN?
Does audio stream ok over that setup?
I have setup a gazillion VPN and while the remote control works there is no audio,
I can't seem to get a definitive answer from anyone including Uniden about whether this is going to work or not, I know I've wasted a lot of time on it.
I guess I must be giving up because I'm looking on eBay and Amazon now for the Whistlers.
I
ilken
Guest
You're not stupid
I spent another good solid 20 hours researching this
IT STILL DOES NOT WORK RIGHT
Audio clipping
Audio artifacts from previous transmissions
no audio over vpn
cannot review ignores
wow
never again
