Setting up frequencies
Mooresville, NC
I just purchased the BCD325P2 and need some help. I have had scanners in the past and am somewhat familiar with some features. I've read somewhere, there may be a site I can download my area frequencies. Is the true, and if so, what is the site/program?
Thank you!
hiegtx
Dallas, TX
Thank you!
As doctor already mentioned, you can download frequencies via web import using FreeSCAN. You do have to be a Premium Subscriber, but it appears you've already signed up for that.
The used guide for FreeSCAN is in the Wiki here on RadioReference.
FreeScan User Guide - The RadioReference Wiki
Also see this page: Freescan Tips - The RadioReference Wiki
If you have not already seen it, there is an Easier to Read manual for your 325P2.
here is a lot of other user information in the Wiki. See https://wiki.radioreference.com/index.php/Category:DMA_Radios_Hints_and_Kinks
Also https://wiki.radioreference.com/index.php/Uniden_DMA_FAQ
And, welcome to RadioReference.
ladn
I use Freescan with my 325P2 and am quite satisfied. I only use the scanner for analog and P25, and within those parameters, Freescan works fine.
Expect a rather steep learning curve with the radio itself.
Mooresville, NC
Thank you so much!
