Simsbury
55engine
Hartford County area
I was kicked off from submitting don’t know why I never asked at the moment it sounds like they’re back in analog but earlier today they were doing radio testing and they were dispatch units On digital and they were also using townwide frequency to DISPATCH units there was a couple police cars that came in I don’t live in that area I cannot pick up that good from the BRISTOL area My radio does not work that good in brick buildings
cg
Connecticut
SPD P25 in service using NAC128.
They were patched to Simsbury Command for a while as cars rotated through getting reprogrammed.
cg
Connecticut
They upgraded their systems but stayed analog.
adamfancher
Winsted, CT
Hi Adam--So do you think Simsbury will eventually go to CLMRN?
I can only give an uneducated guess...but I would say that it's a definite possibility as there was a decent handful of 128xxxx radios in the Bloomfield talkgroup.
I have to dig a bit and see if they are just affiliations at this point or if there is actual traffic.
adamfancher
Winsted, CT
So it looks like I have a total of 18 Simsbury radios affiliated with the Bloomfield talkgroup, and of those 16 have a considerable amount of radio traffic.
cg
Connecticut
When you say there is traffic, are you just going by the DSDPlus numbers? Those are not only transmissions, they are also affiliations. So a line like:
P25, BEE00.3A9, 11101, 1281018, 50, Normal, 109, 2022/02/01 15:30, ""
does not mean they keyed up 109 times. It indicates activity but not just talking. Look in the Event log and search for a busy 128xxxx radio. It will show almost exclusively registering, affiliating, and deregistration.
If you can hear the 453.7500 channel, you can let DSDPlus sit on that channel for specific Simsbury traffic.
adamfancher
Winsted, CT
Hmmmm...this is good info to have. Separating types of activity into several hit counters might be a nice feature for a future release.
It does make me a little curious what drove 18 radios with those ID's to affiliate with Bloomfield in the first place.
cg
Connecticut
New radios, some people like checking things out. There was also some Fire Coordinator and RAFS affiliations.
Then there are those who carry a radio for years and are baffled when they are told to change to a different frequency.
jperuta
Londonderry NH
Probably due to interoperability in case Bloomfield PD and Simsbury PD need to interact.
scanner404
CT
Sounds like they made the switch, I'm picking them up in digital now, where I could barely hear them in analog before. Are they in mixed mode? Also did EMS go digital yet?
On a brief aside, wondering if anyone knows what “ERS” stands for in regards to Simsbury. For instance I hear on the EMS channel “ERS car 10”.
scanner404
CT
Yeah the officers sound ok, but dispatch sounds muffled, like they have a blanket over the microphone. Hope they improve it somehow.
