PSR-800: Site search/change P25 multisite
radionut44
Kernersville, NC
When does the radio look for a different site? On a large statewide system is there a reason to lock out distant sites when you are not traveling or can you just leave the sites unlocked to have them available when you are traveling. What are best settings for data decode low/high thresholds? Specifically I am talking about the North Carolina P25 VIPER system.
Ron
marksmith
Anne Arundel County, MD
Several answers.
You can lock the out of range ones out and you will scan the ones in range faster. Even though the radio doesn't find a signal, it checks for one and this takes time in the scan sequence.
What I usually do is create that system with just the in range sites or as separate systems for each site depending on the situation. Then create separate systems for the others that I can turn on when I want/am in range.
536/996P2/HP1e/HP2e/996XT/
396XT/PSR800/PRO668/PRO652
troymail
Silent Key
On GRE radios, the radio will search each site looking for a quality, decodable signal. When it finds one, it will stay with that site/control channel as long as the quality is above a programmable threshhold value. When it drops, the radio will start searching again for a good site.
To get the best results and have total control while "stationary" (i.e. at home, etc.), the best option might be to treat each site as a separate system. That is - duplicate the system and enable only one site in each scanlist. This way, you can enable and disable the site(s) you want to try to receive. This will force the radio to check the control channel for as many sites as you want even if the closest site is coming in at 100% quality.
This can be further improved by reducing the frequencies in each site's programming to either just the primary and alternate control channel frequencies (where applicable) or even just the primary control channel (assuming it doesn't change much or all all). This is especially helpful for systems that display digital simulcast problems where the control channel is likely to fade.
On the other hand, in mobile operations, I'd program all sites into a single system for just those sites along my route (just the CC frequencies) and let the radio pick the right one as I drive.
...and I nearly never touch the default threshhold settings.
Even though the GREs scan fairly fast, the less the radio has to sift through, the faster you'll lock onto something.
