Working fine
Working fine here in Hidden Springs and while mobile
Jm
Jm
Strange... Happens on 2 radios.
Interesting. The license shows this as part of the Special Emergency Public Safety Plan with a low transmit power(25 watts). Since Pro96Com linked this site with ICAWIN, it's probably tied in as an emergency transmitter available for use by ICAWIN radios, but not for normal use. I'm assuming you didn't hear any actual traffic from this site. Also, Pro96Com seems to put a 1 before the site numbers which actually would be 012 and 006.Site 112 is active per Pro96com when mapping Site 106.
859.4375 Mhz
Tower appears to be near a fire station on E Warm Springs. I can just barely receive the CC signal from my location near the mall.
ULS License - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Trunked License - WQVT470 - ADA, COUNTY OF
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 18B
System Name :
WACN : BEE00
Tower Number (Decimal): 1-12
Tower Number (Hex) : T010C
Tower Description :
Control Capabilities : Data,Voice,Registration
Flavor : Phase 1
Call Sign(s) :
Timestamp : Sat Nov 28 10:29:08 2015
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,764.01250,0.00625,30.00000,"Confirmed",0.01250,1
03,156.47500,0.00500,0.90000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-1113","v",857.96250,"00-1113",812.96250,0,1
"00-1273","v",858.96250,"00-1273",813.96250,0,1
"00-1321","a",859.26250,"00-1321",814.26250,0,0
"00-1349","c",859.43750,"00-1349",814.43750,0,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
103,"T0103",18b,"01-2060",774.88125,""
106,"T0106",18b,"01-2026",774.66875,""
Which is your goto scanner of choice for monitoring P25?
Thanks, I'll add it.Here's the Pro9com output if you want to add it to the DB
The Shafer Butte Site (Site 006 in the DB) is part of the Canyon County System and not part of the Ada simulcast system, so Site 006 and Ada Simulcast(site 003 in the DB) won't necessarily carry the same traffic.Some of you guys may have noticed that some traffic on the Shaffer site is not broadcast on the Ada Simulcast site. For some reason i have trouble getting a very good signal from my location and im wondering if theres much i can do to remedy that problem.
It seems like Valley all call gets more traffic on shaffer then i end up getting via the ada simulcast site. Anyone else out there in Boise have trouble with signal from Shaffer?
good evening all
even though i live in Spokane, WA, i can still pick up on ICAWIN, from the MICA PEAK, and CANFIELD towers for cour d' alene, post falls, and rathdrum
Was wondering what my options are regarding the fact ALL traffic (including Dispatch) in Canyon County are encrypted. A few years back they used the excuse its because of gang activity, however it doesnt seem to have helped them. In fact it keeps residents from knowing whats going on, also it keeps the public from being able to step in and help, say the need ever arised. It creates that grey area when you see cop cars/hear sirens but cant figure out whats going on in your neighborhood. I know in some areas they have gotten encryption overturned, and some agencies are "reopening" their comms into the clear. How would a concerned citizen go about getting something changed on this? How have these other people/towns been successful at such a thing? Or is this just a lost cause?
Ada simucast (site 003) actually consists of multiple transmitters. There is a transmitter on Shafer Butte that is part of the Ada simulcast system, but transmits on different frequencies than the Shafer Canyon County transmitter (Site 006).
Many scanners have trouble decoding simulcast systems very well, due to the fact that multiple transmitters are transmitting on the same frequency at the same time. A scanner may have trouble locking onto the strongest signal from multiple simulcasting transmitters, and thus there may be reception problems depending on your location and antenna orientation. The digital scanner reception problems on the Ada simulcast system have been around for quite a while.
Valley all call would be transmitted over Shafer (site 006) even if the traffic is originating in Canyon County.
I hope what i said was clear.
