Sticky Thread for MilAir II
BM82557
Berkeley Co WV
1713 - HUNTRESS to BRAVE 61 reporting tanker will be a single KC135, cs TANKER 01, but is not scheduled for another hour. They're going to try to be airborne early - 139.7
1717 - BRAVE 61 requesting the status of their replacements, saying "they can text us" - 139.7
Today's logs..
COBRA 72 OC-135B arrive Andrews,req customs,20k fuel.
Guess just enough gas to get home to Tinker.
REACH 7027 C-5 arrive Dover 2030z
REACH 0463 C-5 arrive Dover,uploads 2110z
EVAC 33116 C-17 arrive Andrews 2120z,offload 36 patients,4 attendents.
REACH 512 C-17 07-7169 arrive Dover 2145z
REACH 5005 C-5 arrive Dover 2315z,req c/ag.
REACH 158 up with ETHYL 04 headed to AR Nantuckett 2350z on 305.500
2010 local Delaware National Guard has 2 choppers (1 Huey and 1 H-60) coming into Cecil airport
on 122.800 and heard departing Smyrna Airpark on their Base ops 46.90 FM.
callsigns 167 and 171. rtb later to KILG Wilmington.
2100 ARROW F-15C giving tail EG #80-0020 to tanker on 228.900
TinEar
Glen Burnie, Maryland
2113: SKATER 07 asks HUNTRESS if he can RTB....nope, he's got to wait for TANKER 02 to arrive...228.9
2115: TANKER 02 (KC-135E, 59-1446, 132nd ARS ME-ANG) working his way toward the Guard Dog CAP. (TANKER 01 was aborted and replaced by alert tanker SKATER 07)
2120: HUNTRESS clears SKATER 07 to RTB...228.9
2120: TANKER 02 checks in with HUNTRESS...is told to get his ATC clearance...he's at FL 250...228.9
2121: TANKER 02 calls Potomac (actually, he calls HUNTRESS)...no reply...350.25
2126: TANKER 02 has been calling Guard Dog...no joy...135.525
2127: TANKER 02 is told to go to 126.55 and so he does...checks in at FL 250...126.55 (Then is told to go back to 135.525)
2210-2210: ARROW 23/24 sent after a TOI (track #30166 on the datalink display)...eventually winding up with a "skip it" command from HUNTRESS...228.9
2222: ARROW 23 has HUNTRESS confirm they'll be RTB as fragged "on the hour"....HUNTRESS confirms so ARROW 23 heading for his last refueling with TANKER 02...228.9
2239: ARROW 24 going in for his final refueling...will take 9000 pounds...228.9
2246: ARROW 23 gives Potomac a 14 minute heads up to work their clearance back to Eglin...350.25
Currently 82 degrees at Eglin.
TANKER 02 requests photo ops with both fighters when they finish their AR.
2252: ARROW 23 tells Potomac he'd like clearance to VPS (Eglin) at FL 280 and that they'll be in 2-mile non-standard trail...350.25
2258: HUNTRESS releases ARROW 23/24...23 tells HUNTRESS he'll see him in the morning....228.9
2258: ARROW 23 to Potomac to report ready to RTB and picks up the clearance....350.25
I wasn't listening to 126.55 which is no doubt where TANKER 02 picked up his clearance back to Bangor.
2300: ARROW 23/24 handed off to ZDC-Montebello where they check in at FL 240...several calls, no joy...23 sounds frustrated after his 14th call...they're going back to Guard Dog's freq...284.7
2303: ARROW calls Guard Dog to say no luck on 284.7 so they are sent to 351.9....350.25
2304: ARROW 23/24 check in with ZDC-Gordonsville at FL 240, non-standard...351.9
And that's where I drop them. The players should be back at 0600.
JohnFB
Western Mass
nightwatch said:
braves 61 62 cap 139.700 with huntress block 21 to 23 510pm tanker01 one hour out
You guys down south have all the fun :)
Sat
03-11-07
0919Z : 364.200 TNKR 03 chk in w/HNTRSS FL340 on time.
... and that's probably the closest I get to hearing anything on this GuardDog.
NOTE: YIPES!! is this forum based on Pacific Standard??? I just saw my post tagged as 0443 and its 0743 local.
TinEar
Sat
03-11-07
John, you can set the time zone to whatever you feel like having.
TANKER 03 was a KC-135R, tail 63-8038, from the 133rd ARS NH-ANG at Pease which is why he flew neatly through your area.
TANKER 04 is in now and he's also a KC-135R, tail 58-0099, from the 171st ARW PA-ANG at Pittsburgh. And it was ARROW 23 or 24 that reported his tail as 79-0041 from the 60th FS at Eglin.
ARROW 26 just making it to the CAP area at 1027. His tail is 79-0077.
Unfortunately (for me), they're using 260.9 for primary w/HUNTRESS today. I don't hear ground controller on this freq, only on 228.9.
And John, I expect you to be out at Barnes today to get the tails of those six new F-15s (four yesterday, two coming in today). While you're at it, get the original four too. Thank you. :)
1106: TANKER 04 is already being cleared to RTB to Pittsburgh by HUNTRESS and is getting his clearance from Potomac....260.9/135.25 (Only two hours on station)
And, of course, ARROW 25 is already questioning how far out TANKER 05 is. The F-15 and it's gas station, you can't separate them for long without anxiety setting in.
1109: TANKER 05 trying to check in with Potomac at FL 250...135.525 (He doesn't sound very close.)
TANKER 05 is a KC-135R, tail 62-3551, from the 22nd ARW at McConnell AFB KS
1111: TANKER 04 handed off to ZDC-Hagerstown...134.15 (and he's gone)
1114: TANKER 05 assigned block 210-250...135.525
1114: TANKER 05 checks in with HUNTRESS at FL 240 to enter the area, Mode 3 is 0576....260.9
1119: TANKER 04 with STEEL Control to give arrival message...20 minutes out, A-1, landing with 28K on the fuel, will do a couple of touch and goes before landing...needs parking...311.0
1122: TANKER 05 worried about spray from the nozzle where it connects to the boom. ARROW 25 had just completed refueling. 25 goes back to the boom and 05 confirms a lot of spray from the nozzle...and then it suddenly stops. They then swap tails...ARROW 25 is 78-0003 and 05 confirms what I have above.
1355: Just checking on the CAP...TANKER 06 (KC-135R, 57-1514, 126th ARS WI-ANG Milwaukee, Mode 3 squawk 1327) took over refueling duties shortly after 1300.
I guess they aren't taking any chances with long shifts for the tankers this time. Two and three hour shifts today. Did they finally get it figured out that 4-5 hour shifts don't work when paired with gas guzzling F-15s?
1422: TANKER 06 doing some explaining to Potomac...said she's a KC-135R/W from KMKE, General Mitchell...will be leaving the area around 1930Z...(so they are going to also have a short shift)...135.525
1433: ARROW 26 heading for the tanker for his last refueling before heading home...25 finished his AR a few minutes ago...260.9
ARROW 31 flight on the way to Guard Dog area....12 minutes out per ARROW 25.
1434: TANKER 06 picking up his clearance back to Milwaukee for when he's released per his VOL...135.525
1435: ARROW 31 flight with ZDC-Montebello at FL 230...284.7
1437: ARROW 31 to Potomac at FL 230 for entry into Guard Dog...350.25
1437: ARROW 31 calls ARROW 25 just to make contact...still 40 miles out...says to switch to AUX...260.9
1439: ARROW 25 tries to call him on 228.9 but no contact so back to 260.9 where they meet up and 25 gives him the freqs to work for Potomac and HUNTRESS.
1441: ARROW 25 requesting FL 280 for the RTB and will give 3 minutes notice...350.25
1441: ARROW 31/32 cleared into Guard Dog CAP...350.25
1441: ARROW 31 checks in w/HUNTRESS direct to the tanker....260.9
1442: ARROW 31 reports visual on the tanker...260.9
1451: ARROW 31 off the tanker and on station...25 requests RTB...gets it and checks out...260.9
1452: ARROW 25/26 to Guard Dog to pick up clearance back to Eglin...350.25
1455: ARROW 25 flight reports at FL 250...cleared to Nottingham, Flat Rock, flight plan route...350.25
They also changed to MAN AUX but I can't find their interflight freq. Last night I thought I had them on 302.025 but it turned out to be someone else.
1458: ARROW 25/26 handed off to ZDC-Brooke and check in at FL 250...327.0
1459: Found the interflight freq for ARROW 25/26....it's...259.55
1505: ARROW 25/26 talking about the Guard call back in the DC area that happens, of course right after they leave....259.55
1505: ARROW 31/32 getting a TOI to check out....260.9
1507: ARROW 25/26 handed to ZDC-Blackstone and check in there....requesting direct VPS (Eglin)...235.625
1509: ARROW 31 doesn't see anything in the area he was sent to to check out the TOI....32 reporting a lock on something at BRA 240/9/3600...260.9
1511: ARROW 25/26 still talking about the actions by ARROW 31/32 back in the CAP...(they sound jealous)...259.55
1512: ARROW 31 reports he has the TOI on timber but not where he's showing him....260.9
1513: ARROW 31 gets the "skip it" command from HUNTRESS....31 says they had one good lock on it and then nothing after that...260.9
1520: TANKER 07 (KC-135R, 63-8018, 173rd ARS NE-ANG Lincoln, Mode 3=3635) to HUNTRESS to report he's on his way and will be here at 1945Z...260.9
Someone was calling TANKER 06 on 135.525 and 260.9 but they never could figure out who it was...06 then went to 126.55 to try there. Probably TANKER 07.
1533: TANKER 07 makes contact with Guard Dog and told to enter at FL 250...135.525
1533: TANKER 07 to HUNTRESS and will stay at FL 250 until TANKER 06 departs...260.9
1537: TANKER 07 cleared into Guard Dog in the block 210-250...135.525
1538: TANKER 07 repeats above...said he answered a couple of times but apparently wasn't heard...135.525 (Guard Dog/Potomac seems to be hard of hearing today...several aircraft have had to repeat transmissions several times.
1539: TANKER 07 sent to 126.55 to see if that's better...apparently it is.
1541: TANKER 06 picks up his clearance from Potomac and is handed off to ZDC-Hagerstown 134.15....starts a climb to FL 300 and flashes a new Mode 3 of 5614...126.55 (Looks like they're going to use this one instead of 135.525 now)
ARROW 31/32 and TANKER 07 are now established in Guard Dog and all is quiet.
1920: Checking back to see what's up with the CAP...guess TANKER 08 had an abort...the alert tanker had to come in again to replace TANKER 07just before 1800. It's SKATER 07 (KC-135E, 57-1464, 108th ARW NJ-ANG McGuire, Mode 3=2672) ARROW 33 [female] and 34 are the Eglin F-15s.
1930: And now TANKER 09 (KC-135R, 62-3542, 77th ARS Seymour Johnson, Mode 3=5360) is approaching Guard Dog CAP and has just been cleared in at FL 250 by Potomac...135.525
1938: SKATER 07 to Potomac to announce RTB in five minutes...he's told to use 126.55 but says this freq is working well too...nope, they want 126.55....135.525
1941: SKATER 07 for RTB clearance...cleared down to FL 200....handed off to ZDC-Swann 134.5 at 1943....126.55
1947: TANKER 09 checking to make sure he's got the block 210-250...he does...135.525
1947: TANKER 09 leaving FL 250 for 240....260.9
2259: TANKER 09 to Potomac to get clearance to GSB (Seymour Johnson) through Richmond in 5 minutes...350.25
2300: ARROW 33 to Potomac for clearance back to VPS (Eglin) in a few minutes...2 ship in non-standard radar trail 2 miles...350.25
2304: TANKER 09 cleared to RTB by HUNTRESS...260.9...over to Potomac for their clearance to GSB...350.25
2305: ARROW 33 flight to Potomac for clearance to VPS...350.25
2307: TANKER 09 handed to ZDC-Calvert 133.9 to begin the trip home (and we're done with him)
2309: ARROW 33/34 handed to ZDC-Montebello and check in there at FL 220....no joy to first three calls...so it's back to Potomac on 350.25 but that operator apparently already called it a night so there's no reply there either...back to Montebello she goes and still no reply...284.7
2313: ARROW 33 now tries calling ZDC-Brooke on freq 327.0 while 34 keeps trying on 284.7....33 gets someone to reply on 327.0 and explains the problem.
2314: ARROW 34 gets a reply on 284.7...requests FL 280
2315: TANKER 09 calls LIGHTHOUSE CONTROL (Seymour Johnson) for Blackjack report...
Item 1...20 minutes (minutes from home)
Item 2...A-1 (maintenance condition)
Item 3...61.0 (total fuel offload)
Item 4...29.0 (fuel remainder upon arrival)
Item 5...fragged (as planned for some function)....311.0
CAP done for the night and will resume at 0600.
1538-46: Couple of McGuire KC-10As (83-0079 and 79-1712) yakking on interplane Victor-1...they're going to get established at 26,500 and 27,000 feet...139.875 (Believe they are TEAM 65 and 66)
OCEAN 81 (C-130J, 05-1465, 115th AS CA-ANG) was off from New Castle at about 1125 and heading for Gulfport MS with DE-ANG troops aboard. Heard flying over Atlanta around 1330.
CARMEN 1 (C-130H, 84-0206, 142nd AS DE-ANG) departed New Castle around 0920 and about 1120 was heard in Georgia so he's no doubt part of the fleet heading for Gulfport also.
No word yet on the two C-17s (03-3119 as RULER 50 and 03-3113 as RULER 60) from the MS-ANG that landed at New Castle yesterday.
CARMEN 4 (84-0209) and CARMEN 6 (90-1057) from the DE-ANG also noted this morning but I'm not sure if they're also heading that way or not.
CARMEN 6 is apparently on his way to Gulfport since he's being heard in GA late in the 1200 hour.
RULER 50 (C-17A, 03-3119, 183rd As MS-ANG) out from New Castle around 1220.
RULER 60 (C-17A, 03-3113, 183rd AS MS-ANG) off from New Castle around 1345.
1420: Our regular visitor from the Belgian Air Force -- BAF 628 (A-310-222, tail CA-01, 21 Squadron) into the area....TRACON
I've been meaning to mention this the past few days and keep forgetting...until now. McGuire KC-10s have been noted the past few days using callsign CLEAN. That's a new one for me and I've added it to my database. I'm wondering though if it's strictly for McGuire or if it might be a Coronet or mission type callsign. I've seen it three times now and it has only been with McGuire KC-10s. CLEAN 91 and CLEAN 01 are flying today (87-0121 and 86-0027.) They were noted in the 1600 hour. At the same time, in the same area, were two KC-10As from Travis -- CACTI 61 (85-0029) and EXTENDER 88 (86-0033.)
I was out and missed them Tin so good job.
DE ANG usually use CARMEN callsign when on long road trips so more
than likely they are headed for Gulfport as well.
That tail #90-1057 was Hawaii ANG but think was replacement for one of the 166th
C-130H that was destroyed in that twister a few years back.
BM82557
Berkeley Co WV
Activity 11042007
Copied first shift replacement this morning. Heard incoming COSMIC 41 flight on 138.2 and with ZDC-SWANN at 0917. Outgoing flight was from Langley but I am not sure of the callsign. At 0920 heard DALL (??) 02 saying "back to Langley in 5 minutes". AT 0923 heard DALL (??) 01 flight reporting block 21 -22 in the north. HUNTRESS released them to rtb to Langley at 0931.
TinEar
COSMIC 41/42 are F-16s from NJ-ANG Atlantic City....138.2 (COSMIC 41 muffled transmitter)
DIAL 01/02 are F-16s from VT-ANG Langley Detachment...138.0 (Had first shift this morning)
Plus 260.9 w/HUNTRESS
Eglin can't get off the ground perhaps? Rain?
First gas station was TANKER 10 (KC-135R, 63-8038, 133rd ARS NH-ANG Pease, Mode 3=3413)
0944: TANKER 11 calls in from some distant point to say he's on his way....260.9
0954: TANKER 11 reports at FL 250 to Potomac...135.525
TANKER 11 (KC-135R, 59-1504, 171st ARW PA-ANG Pittsburgh, Mode 3=0752)
0958: TANKER 10 to Potomac to request clearance back to PSM (Pease) in 5 minutes....135.525
1000: COSMIC 41 heading for TANKER 11 to refuel...260.9
1002: TANKER 10 wants confirmation his new Mode 3 is 6252...it is and he makes the change...135.525
1009: TANKER 10 Heavy still looking for his clearance out of Guard Dog...cleared to PSM and gets his flight route...135.525
1011: TANKER 10 to HUNTRESS to report "finally" leaving the airspace at FL 250....260.9
1012: TANKER 10 handed off to ZDC-Brooke and checks in at FL 250 direct Swann....126.875
1014: COSMIC 41 off the boom after taking 6,000 pounds of fuel...tells HUNTRESS he's back in the CAP....260.9
1124: COSMIC 41 reporting he has an SCR (or FCR) 218 and 005 and that both of those are giving him a pressure warning...260.9
1250: HUNTRESS releases the COSMIC 41/42 pair and TANKER 11 to head home. The F-16s used their 138.2 freq for interflight chat while heading back to Atlantic City. TANKER 11 is handed off to ZDC VHF freqs to head back to Pittsburgh.
1003: ZNY-Middletown is active...322.4 (Might be Willow Grove A-10s...briefly heard 143.75 interflight active also)
Nope, it's MOHAWK 2 flight. Doesn't sound like a fighter and all I have in my callsign database for MOHAWK are fighters.
1007: MOHAWK 2 handed to ZNY-Lancaster and checks in there at 9000 feet....239.05
Ref Below: Glad to be of help Mark. I suspect CLEAN is a mission type callsign and not strictly for McGuire. Your QID 90 bird was 60-0328 if you're keeping a record.
CLEAN could be a new Coronet callsign but we'll see. I note they are mixing the new callsigns HURON/TABOR with the old TREND/MAZDA and even still using BLUE/GOLD sometimes. Perhaps flights that were scheduled long in advance of the change are maintaining the old callsigns. I just don't have enough evidence to call it.
Rgr and thanks Tin as I kept playing tape over and over again trying to
figure that out and then replayed after seeing your post and you are right.
Last night had CLEAN 92 and CLEAN 02 into McGuire 2300z and 0135z.
In between had a QUIID 90 which further added to my confusion but that is clearly
a Mildenhall KC-135.
I'm guessing some type of Coronet or mission callsign but guess we shall see soon.
1112 local 2 Del ANG choppers up and about A/A 242.400 chatting about plane down near Farmington Delaware .
Unknown type but said ELB was pinging.
Update on above from News Journal...
Plane crash near Farmington kills 2
Posted Sunday, November 4, 2007 at 2:11 pm
A small airplane crashed into the woods near Farmington this morning shortly after takeoff, killing two people.
The crash occurred at 10:11 a.m. today near the 3200 block of Andrewville Road, said state police spokesman Cpl. John Barnett.
The plane took off from Cormans Airport, on Nine Foot Road, at 10 a.m.
Investigators believe the pilot and passenger were the only two people on board the plane when it crashed. Both were killed, Barnett said
bigred10
PA
Willow Grove A-10's are active this morning. I haven't had a chance to listen to the scanner but I think at least 3 different flights took off around 9 AM. In fact as I type this message 3 A-10s just flew by the house as they RTB.
On a separate note I finally got to see the V-22's on Friday...definitely a unique sight and sound. They could easily be mistaken for a helicopter, when I first heard them I though it was a CH-53. Another forum had their interflight on 251.4
trainman111
Richmond, VA
2150 - MARLIN 35 (?A-10, 103rd, FW Bradley ANGB, MA?) is out of 27.5 for 20. <118.75>
2152 - OTIS 21 (KC-130, VMGR-251, MCAS Cherry Point, NC) reports switching to Tower (unknown what tower exactly...). <118.75>
Overnite tape had CLEAN 82 with McGuire CP at 0120 local looking for CLEAN 81
and CLEAN 92 checked in as well.
Meeting recievers at 0635z.
I understand a couple Coronet East missions this week with Spangdahelm F-16's returning
to Europe as well as their A-10's.
CitationJet
Northern Virginia
Re: MARLIN 35
MARLIN 35 is actually a LJ35A N565GG based out of HEF and which flew SRQ-HEF last night at the time you heard him.
2152 - OTIS 21 (KC-130, VMGR-252, MCAS Cherry Point, NC) reports switching to Tower (unknown what tower exactly...). <118.75>
TinEar
I was up late last night listening for them and managed to log all four of the CLEAN tankers as follows:
CLEAN 81...KC-10A, 87-0121, 305th AMW McGuire
CLEAN 91...KC-10A, 86-0027, 305th AMW McGuire
CLEAN 82...KC-135R, 61-0310, 133rd ARS NH-ANG Pease
CLEAN 92...KC-135T, 58-0125, 92nd ARW Fairchild
I'm just not sure who their receivers were. It should confirm CLEAN as a new Coronet tanker callsign though. Mark, you might be right about the Spangdahlem fighters and that might have been who it was. I had a couple of CLEAN tankers going down south Saturday. The SP guys have been working the Avon Park Range in Florida all of last week and were probably at Patrick or MacDill.
CLEAN 82 and 92, the KC-135s, apparently went only as far as Nantucket or a little beyond last night. Both KC-10s were heard in the U.K. this morning.
Edit: And I just got confirmation they were the SP F-16s in two flights -- TABOR 31-34 and TABOR 41-44. CLEAN 81 and 91 apparently went into Mildenhall and the F-16s continued on to Spangdahlem.
FENDY 45, a C-20H, 90-0300, from the 76th AS Ramstein AB departed ADW this morning in the 0700 hour. He arrived from Europe yesterday around 1400.
1008: Royal Air Force...ASCOT 2536, VC-10 C1K, tail XR808, 101 Squadron overhead and heading northeast.
1032: Belgian Air Force...BAF 628, A-310-222, tail CA-01, 21 Squadron departs the area.
trainman111
Richmond, VA
Had a visual about 45 mintues ago on a KC-130 heading towards Ft. Pickett. Didn't catch anything on the radio though.
1056: "REACH 424T cleared direct Randolph." <121.675>
1257: "Washington Center, DUKE 38 with you FL 230. <133.975> unkown acft type.
1358: Activity on 311.000. It's weak and barely readable, but it sounded like an EAM.
1524: Have some activity on one of VMAT-203's frequencies, 337.000. It's a female speaker. I had 4/5 bars on signal strength.
1525: u/i calling "Maintenance, 692". x2, no reply. <337.0>
trainman111
Richmond, VA
I was quite surprised to find him on flightaware.com. Right now it shows him over Rhode Island; departed from Andrews AFB enroute to Brussels Nat'l
TinEar
Nick, REACH 424T was a C-17A, 00-0176, 62nd AW McChord AFB WA. Nice catch.
1149: PISTON 51 (KC-135R, 60-0346, 63rd ARS Selfridge ANGB MI) to Giant Killer as he crosses through W-107 getting a flight plan route at FL 320 to his RTB destination of MTC (Selfridge)...255.0 (He's eventually handed off to ARTCC 135.125 at 1201)
1150: REACH 370 (C-17A, 01-0197, 437th AW Charleston) to Andrews Cp with arrival message...ETA 1715Z, 21 pax and 1 "Special Person"...need fleet service on lav and ATVLs...transportation for pax and 8 crew members...will need 25K fuel upon landing
1246: JAWS 21 (probably an MC-130P from the 9th SOS Hurlburt Fld FL) to Oceana Approach...will meet up with DOG 31...266.8
1346: E-6B, 164386, VQ-4 passing over Waterloo (DE) at 10,000 feet heading for Patuxent on a course of 260 degrees.
More foreign flags...
1109: Royal Air Force....ASCOT 5324, C-130H (C3), XV307. Lyneham Transport Squadron
1202: Royal Air Force...C-130J (C5), ZH881, Lyneham Transport Squadron
1228: German Air Force...GAF 129, A-310-304, 10+21, FBS (Heard in the UK in 1000Z hour this morning)
1310: Egyptian Air Force...EGY 1122, C-130 (tail 1297?)
Ref Below: Agree Nick that he was talking about Randolph AFB TX.
trainman111
Richmond, VA
I'm going to guess and say that he is going to Randolph Air Force Base in Universal City, TX. Would that be a good assumption? It's the only "Randolph" I can think of.
