CitationJet said:
Hi Tin,
The 126th ARW IL ANG transferred to Scott AFB from ORD in 1999, just to update that entry on the callsign list.
Best regards,
Tony
Spasibo, mam'noon, takk, shukria, toda or just simply thanks Tony. (Language practice)
I'll make the change to the list.
2000-09: HOIST 95 (KC-10A McGuire AFB) has been trying to get his arrival message to McGuire Command Post but is having difficulty. He's tried a couple of different transmitters. At the start, he was 20 minutes out, A-2 and has zero pax or cargo...just wants parking. He apparently is also having trouble with a request for a quick turnaround - said they called from their last station to get it arranged and he tries to describe the voice of the female he talked with. Says he'll call when he gets closer...319.4
2113: REACH 461 to Dover CP...no reply...349.4
2118: REACH 461 to Dover CP with arrival message...15 minutes out, IDs as a C-5 on the way to Ramstein (Germany), is A-2 for a left center door - the troop door - needs to be adjusted because the light is on indicating door is open. It happened when climbing out from Wright Patt(erson AFB)...wants info on upload then asks if it's hot cargo...349.4
2127: REACH 461 adds that he has 5 pax on board - 3 going through and 2 for Dover...349.4
2142-44: PETRO 41 [female] (KC-10A McGuire) calling McGuire Command Post...x3, no replies...319.4
2147: PETRO 41 makes contact with McGuire CP for arrival message...ETA 0313Z, A-2 with multiple writeups, zero pax or cargo, needs airstairs...319.4
2149: PETRO 41 calling McGuire again and gets no reply...319.4
2151: PETRO 41 makes contact with McGuire to ask if they received her last message...apparently MCP didn't so she repeats the arrival message and adds that they have 13 writeups. She gives the first as the ground warning system is inop along with a couple of others (that I wasn't fast enough to copy)...says the rest are minor...says they're TDY and have crew bags.
[We've been assigning PETRO as McGuire based but I'm not so sure of that. It appeared PETRO 41 was indicating they're TDY to McGuire which would make them from elsewhere.]
2155: ?GUMBY? 07 (Same aircraft I had earlier today that I thought was GUPPY. Still not sure if it's GUPPY or GUMBY...sounds more like GUMBY this time.) He's calling "Metro" on 356.2 which is a Willow Grove Metro freq.
2157: PETRO 41 gets parking spot India-3...319.4
2158: REACH 461 still in the air around Dover...mentions something about ILS problem...349.4 (He should have landed about 25 minutes ago per his arrival message.)
2203: GUMBY 07 with ZDC-Brooke heading for FL 260...327.0
2204: GUMBY 07 handed off to ZDC-Calvert and checks in passing 30,4(00) for FL 260...281.4
This guy just doesn't enunciate clearly which is why I'm having trouble with his callsign. GUMBY is good for A-10s from the MA-ANG Barnes if that's what it is. GUPPY is a KC-135 from IL-ANG Scott AFB as mentioned this afternoon when he was calling HUNTRESS and OAK GROVE. (See log 1538-1541 above)
2209: GUMBY 07 with a request to ZDC-Calvert...says he's heading for Flat Rock (FAK) and after that wants to go to Pax (PXT)...then repeats PXT three more times. (Guess the controller can't understand his flat, monotone voice either.)...281.4
2212: GUMBY 07 handed off to ZDC-Blackstone and checks in and repeats his request for PXT after Flat Rock...235.625
2214: GUMBY 07 mumbles something about a full stop (possibly at Pax)...235.625
I don't believe this guy is either an A-10 or a KC-135 whether his callsign is GUMBY or GUPPY.
2216: REACH 3031 calling Dover Command Post...mentions Mildenhal...tail number is 3-8031..gives ETA as 0930Z (which must be for Mildenhal, not Dover)...349.4
Tail number is probably 63-8031 making him a KC-135 from the 91st Air Refueling Squadron at McDill FL.
2216: GUMBY 07 cleared direct Richmond and then Patuxent...235.625
2222: REACH 3031 asking Dover if they've heard anything from TACC yet...349.4
2222: GUMBY 07 cleared down to FL 230...235.625
2225: GUMBY 07 cleared from FL 230 to 190...then making a left turn toward Patuxent...235.625
One transmission sounds like GUMBY and the next GUPPY.
Sure wish someone else was listening to this guy...I think he's probably loud enough and clear enough for most people but it must be some aversion I have to his vocal tone that prevents me from understanding him.
2228: REACH 3031 to Dover CP telling him he's 16 miles east of Dover flying along the coast toward McGuire and then Gander and the Atlantic area...349.4
2234: REACH 3031 asking for a radio check from Dover...then asks if "they" still have him on hold...349.4 (It appears he's not going to Dover at all...he just had Dover checking something out for him with another party at TACC.)
